vp and lp replacement
This ought to help. Good luck!
http://www.nwbombers.com/membersites/kent/vp44.html
and that not a bad price, jetpilot can set you up on a rebuild one for $999 on the vp he's a pretty good ole boy
Blue Chip sells both new and Remaned. You will of course have to pay dear for the new, but being new with the 1 year warranty, regardless of mods to me still makes it a good buy. It's a sure thing thing.
Originally Posted by 99 cummins
Just make sure the VP is new, the Reman's are a luck of the draw. Don't settle for anything less than a year warranty either.
There must be some new ones out there somewhere, but they are no longer being mfg. by Bosch (03 and newer used different pumps).
I think you will find Blue Chips "New" is remanufactured with all new (and Fed Ex) parts.
All VP-44's being remfg now have the same electronics as the FED EX calls for, according to one Bosch approved service center..
RJ
RJ
....being new with the 1 year warranty, regardless of mods to me still makes it a good buy.
RJ
Acording to The owner of Blue Chip the warranty is good even with the wire pierced, he sold me the pump cover to peirce the wire with. He has pumps that are listed as reman's and he also has different pumps that are sold as new, both available with the optional advanced electronics.
Originally Posted by rjohnson
Good info...thanks. First I've heard of 1 yr being honored if wire is pierced. Wonder if that is Blue Chip honoring it. Bosch told me they won't?
RJ
RJ
All the better reman pumps have a 1 year warranty, they all will warrant the pump with the wire pierced!! none will warrant the electronics with the wire pierced!! Got it!! yes on pump, no on electronics. Guess what most failures on the remans are electronic!!
Get a pump from a reputable rebuilder, such as Industrial Injection! don't be afraid to ask who rebuilds the pump you are buying. Industrial Injection makes a very good High Performance VP-44. I recommend it!!
i just went thru this. my lp and vp went south also. i got a lp from pep boys for 180.00 and then i was able to drive it out to jetpilot for the hot rod vp44.. awsome guy will reccomend him to anyone and everyone.....
Originally Posted by RickCJ
All the better reman pumps have a 1 year warranty, they all will warrant the pump with the wire pierced!! none will warrant the electronics with the wire pierced!! Got it!! yes on pump, no on electronics. !
guess it would be smart to install a fuel pressure gage in the cab. any good links.. aslo the jetpilot vp44 will it give me more power by just installing the pump or do i have to do other up-grades
