VP-44 electronics
Old Jul 15, 2005 | 03:53 AM
wings's Avatar
VP-44 electronics
Hi,
I naturally follow the vp-44 threads as I have one that's been around for 140,000 so far. I was on another forum and a guy says he and 3 friends have bought replacement electronics only for the VP-44 from a Bosch dealer. One has a 99 just like mine. I thought the electronics were not available to the puplic. This guy isn't a dealer, maybe a local repair shop worker.
I sent a message to him and replied to the forum, not challenging him but only asking where so I can possibly try to get one myself and post the place here. So far I haven't heard back.
Anybody know if you can buy the electronics only??
betnwings
Old Jul 15, 2005 | 06:04 AM
storx's Avatar
i think dodge can special order it if im not mistaken
Old Jul 15, 2005 | 07:21 AM
P.J's Avatar
P.J
I tought the electronics were mostly internally located and would require a complete disassembly? If I had 140K on a OEM pump I would be intersted in a reman or brand new pump just for the sake of having ALL new parts. Just my opinion.
Old Jul 17, 2005 | 10:24 AM
neveragain's Avatar
vp electronics
Sorry for not knowing but what electronics for the ?? I am looking for electronics that can tell me why the engine isn't running the way it should from new every one that has looked at it says it is fine or good ( which it isn't) looking for more answers. Never again will I have cry/ dog/****/bos , garbage.
Old Jul 17, 2005 | 10:32 AM
Big Deezul's Avatar
^^what??
Old Jul 17, 2005 | 11:21 AM
JDGnut's Avatar
http://www.turbodieselregister.com/u...&albumid=17275
I don't know if you can get the parts... but I would think that the cost would be expensive... and the solenoid at the back should be calibrated to the pump... If you decide on a VP, Chris at Relentless Diesel has a special on VP's this month..
Good Luck
Bryan
Old Jul 17, 2005 | 11:38 AM
Big Deezul's Avatar
Good Luck
Bryan
do you have a link for relentless?
*edit http://tmsyn.wc.ask.com/r?t=an&s=hb&...essdiesel.com/
Old Jul 18, 2005 | 11:50 AM
CTD NUT's Avatar
Re: vp electronics
Ok, the last sentence lost me!?!?!
Old Jul 19, 2005 | 07:47 PM
JAFAW's Avatar
You can not replace the pumps computer with a new computer unless you calibrate them together on a test stand. If these are being sold the are likely used units that are past the bosch tsc date. And chances are they won't last long. The old computers can only take so many heat cycles. Plus if you loosen the mag pickup on the driveshaft inside of the pump you have to calibrate that setting as well. And that is done before the pumps computer is calibrated.
Old Aug 1, 2005 | 12:04 PM
neveragain's Avatar
vp-44's
Hello CTD NUT
The cry/dog/****/bos. garbage is cryslurr, do_g_ , cummins, bosch
I have been pestering all of the above and none of them are of any help. They all point to the right and around we or ( I go again).
Talked to a Cummins manager the other day and he said it's funny that you know more about the engines than we do. He said that ifl the voltage is above 8.5 volts that is above what the ECM needs. to operate. But what they don't know about is bad / corrupted voltages.
COLDHEART
Apr 26, 2004 11:25 AM
COLDHEART
Apr 19, 2004 08:33 PM
INsIdious
Apr 3, 2004 01:55 AM
Randy J
Oct 28, 2003 07:56 PM
