Vibration from motor?
Old Mar 13, 2007 | 06:38 PM
dutchboy's Avatar
I just got back from a 650 mile trip and noticed on the first 325 miles anywhere above 2000rpm the motor has a steady vibration. Its not quick it hits every second. On the trip back the last 60 miles it was hitting anywhere above 1500rpm. Its not the tires there brand new, and when the vibration starts if I push in the clutch let off the pedal it's not there. It's not a knocking, it dosen't affect performance but it seems to be something that needs to be addressed. Any help would be much appreciated?
Old Mar 13, 2007 | 07:53 PM
gunnie's Avatar
are you sure its the engine? sometimes when a u-joint is going out you'll feel this vibration. after a short drive 3 or 4 miles slide under the truck and feel both u-joints if one is just beginning to go out it'll be rather warm to the touch
Old Mar 13, 2007 | 08:02 PM
dutchboy's Avatar
I will check it out. It seemed to still have the vibration at 2000rpm in neutral.
Old Mar 13, 2007 | 08:31 PM
gunnie's Avatar
well if it was in nuetral and not moving it isn't u-joints, tell us more , could it be a miss?
Old Mar 13, 2007 | 08:49 PM
dutchboy's Avatar
The truck was moving, what I did when I was driving @ 65mph about 2200rpm
the truck starts the vibration. I push in the clutch and let it coast @ idle no vibration. With the clutch still pushed to the floor rev the engine to 2200rpm some vibration not nearly as noticable. Let out the clutch there is the vibration again @ 2200rpm.
Old Mar 14, 2007 | 10:59 PM
BigPapa's Avatar
I had a vibration between 1800 & 2000 RPM that turned out to be the clutch hub coming apart. The hub came apat and one of the springs came out. I think the initial vibration was when the piece of the plate came off and threw the balance out on the clutch. It probably weighed about as much as 2 quarters. When the spring came out the vibration was worse at idle than at speed.
Scott
Old Mar 15, 2007 | 04:56 PM
Silverfox99's Avatar
I know this is probably not the problem but you never know .... I have a 4inch downpipe off my turbo also and after a while having the exhaust it would vibrate only at certain points ..........just another thing to throw in i spose
Old Mar 15, 2007 | 06:58 PM
DSjockey's Avatar
Another vote for a U joint, I had some extra vibration and it was in fact the rear U joint, I'll be replacing them all tomorrow
Old Mar 30, 2007 | 11:15 PM
whiteknight's Avatar
Dutchboy! i have same problem with 98 I just got back from 3000 mile trip to california and same problem as you, I can get mine to vibrate in 2nd gear as well as crusing at about 65 or 55 mph it drove me crazy I can feel it mainly in the throttle petal push in clutch and coast its gone! rev engine while coasting I feel nothing seems when ever there is a slight load on it is when it comes to life! I can even hear it barely grrrrrr grrrrrr grrrrr I have a fuel gauge that is temporary (piped with stainlees steel) that is laying on the floor board by the shifter I can really feel it in that also I cant feel nothing in shifter ect (like I could on my past chevys with drive train problems!
Someone please help!!
SeanB23
Jun 1, 2009 06:44 AM
ryan10
Aug 10, 2007 09:38 PM
Common
May 9, 2007 12:11 AM
coupdetat
Feb 17, 2007 12:52 AM
dodgedsl03
Jan 18, 2007 10:08 PM
