Vibration
Vibration
I have a 2001 2nd gen with 305/70/16 new wheels centramatic balancers new drive shaft ,front wheel bearings ,axle joints u joints and transmission mount and it still at 44mph and 68 mph my teethl chatters
the torque converter is a triple disk plz help thanks in advance the vibration fill like it in the floor.
Cummins Guru
two piece rear driveshaft or one piece? new drive shaft front or rear? any vibration felt with rear wheels off the ground running at 44mph in gear? Any wobble or run out in drive shaft? Did you disconnect front drive shaft and drive truck to see if vibration was still there? If two piece drive shaft did you try turning rear shaft 180 to front? Do you only get vibration while moving, no vibration felt in neutral or park?
Dads 94 had a wierd vibration that picked up greatly over 70 mph. After 3 or 4 driveshafts, two sets of replacement tires,numerous balancings, brake drums and a complete rear end change out, it never ceased. Old mechanic in Kalispell says, did they ever check your wheels. Sure enough, two were over a 1/4" out of round. The other two were out about an 1/8'.
Chrysler "lost" the two worst ones. He finally bought a set of aftermarket alloys and the vibe stopped
Just trying to help, sometimes its the most obvious things that get overlooked..
mine has this vibration and feels like under the floor chased it for years now and never got better or worse, guess it is like the loose steering throw lots of money at it and still won't be fixed
Finding two vibration speeds is telling me its a reciprocating event, I'd keep after the tires and driveline
I did springs, tires, both drive shafts, carrier bearing, shocks, trackbar, 09 tie rods, energy bushings on sway bar, energy busgungs in front trailing arms, steering box and brace, still vibration under trans hump on highway and steering still loose I gave up
Also tried replacing the lower column bushing, waste of money imo
