Vibration
Vibration
I had a vibration so I changed out the rear u joints. The were pretty dry. I still have some vib that starts around 30-35 miles/hr. No vib when coasting. any suggestions? 2002 short bed 2500.
Craig
Craig
I had a vibration at 40-43 MPH and it ended up being my tires. Got rid of the mud terrains and went with a calmer tire and havnt felt it since. However it would be worth it to check all of your fluids (t case-trans-rear end)
Does it seem like its coming from the front or rear more?
Pinion bearings. They will howl during acceleration and be dead quiet on coast.
You didn't mention the U-joint issue in the beginning. If you pushed on it that hard you will have to replace it again. The roller that dropped will have a flat on two sides. If you still have the old U-joint and one of the caps was good you can steal a roller out of that one. Not reccomended but I have gotten away with it when I dropped a cap and lost some of the rollers. Just keep in mind that the joint will probably not last as long as a new one though.
Rick
Rick
fixed
ok so I pulled the shaft back out and went to lowes for another vice(that one broke also). Pressed the end cap that would not go in and inserted the clip. Replaced the shaft and "evenly" snugged down the "C" clips at the rear dif. Guess what? No Vibration. Saved $200 over what PepBoys wanted to do the job.
Now to the front shaft.
Craig
Craig
Cummins Guru
That's why I send to driveline shop in town. $50 and they replaced all the ujoints and even painted the driveshaft. I supplied the parts. Sounds like you have bent drive shaft or severely out of balance take it to drive line shop that is capable of balancing driveshafts
dodgedsl03
Jan 18, 2007 10:08 PM
Davidp
Mar 19, 2003 11:29 PM
