valve cover gasket
Old Sep 3, 2012 | 03:17 PM
craigwill's Avatar
valve cover gasket
2002 2500 4x4
Time to adjust the valves or past time 175,000. Is the gasket reusable or do I need a new one($123.00).
Craig
Old Sep 3, 2012 | 05:26 PM
SIXSLUG's Avatar
You won't really know until you pull the cover, if its cooked, cracked or broken, replace it.
Old Sep 3, 2012 | 07:03 PM
lovinCTD59's Avatar
I have had my valve cover off 3 times now, once for injectors and twice to adjust the valves over the years. It hasnt started to leak yet. Just be careful not to tear it on the valvetrain if its stuck to the bottom on the cover and not the head.
Old Sep 3, 2012 | 07:45 PM
craigwill's Avatar
Thanks for your help.
Craig
Old Sep 4, 2012 | 09:21 AM
jhenson's Avatar
You should be fine as long as it's not knicked or torn. Genosgarage.com has them for way less than you listed. Good luck.
Exekiel69
Aug 4, 2008 11:43 PM
chuxtruk
Apr 5, 2006 05:16 PM
n5oxp
Sep 20, 2005 06:19 PM
thepunkno1
Mar 10, 2003 07:41 AM
Garz
Dec 25, 2002 09:45 PM
