unknown sensor
Old Mar 7, 2008 | 10:50 AM
TOM R's Avatar
unknown sensor
while installing some parts this morning i noticed there is a large sensor on one of the fuel lines down on the block at the front of the engine and nothing is plugged into it any ideas? maybe a fuel pressure gauge sender? truck has no extra gauges installed yet
Old Mar 7, 2008 | 10:53 AM
vzdude's Avatar
DTR's 'Go to Guy'
Gonna need a pic! Had the truck long? Previous owner have guages? Fuel lines should go straight from the filter to the injection pump.
Old Mar 7, 2008 | 11:22 AM
TOM R's Avatar
ok i uploaded pics to my gallery waitin on the aproval, it is on the line that runs straight from the fuel filterto the front of the engine
Old Mar 7, 2008 | 01:42 PM
sledcrusher02's Avatar
sensor
looks like a f/p sensor at the injection pump its hard to see the small pic.
Old Mar 7, 2008 | 02:31 PM
TOM R's Avatar
[/IMG]
hows this
Old Mar 7, 2008 | 02:38 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
That "block" is your VP-44 injection pump. That does look like a fuel pressure sending unit of some type. Maybe the previous owner had a gauge ay one time or another?
Old Mar 7, 2008 | 03:35 PM
TOM R's Avatar
ok just wanted to be sure it was an extra
Old Mar 7, 2008 | 03:51 PM
xtoyz17's Avatar
Definitely from a gauge. Find out what it was and order a new display. Voila, instant fuel pressure gauge!
Old Mar 7, 2008 | 04:46 PM
TOM R's Avatar
well i live in n.j. and bought the truck from a dealer in tx so.... unless someone can id it from the decal
Old Mar 7, 2008 | 07:28 PM
ggg95gt's Avatar
Smile Low fuel pressure sensor
I also found this part after I purchased my truck, I later found a bag under the front seat with the installation instructions for a low fuel pressure warning light ( if fuel pressure drops below 5 psi. light comes on). I then realized that the small red light on my drivers side windshield post wasn't part of the security system but was for the low pressure switch. I looked closer under the hood by the fire wall and "voila" I found a very small guage wire that had broken off the connector on this switch you have. I replaced the wire with some heavier guage thermal wire and wire ties, and this red light has come on(flickered) after a long drive. I picked up some replacement cartridges for my fuel filter housing and replaced the filter as it was very dirty. This seems to have helped the low pressure problem to the injector pump from the lift pump. Though I am still going to replace the lift pump as a precaution, just haven't decided on which one. I am leaning towards a belt driven type.
Old Mar 7, 2008 | 07:34 PM
JPR Ram's Avatar
I think you have a winner on that one. I really didn't even think about, but most electric fuel pressure senders are bigger and have two wires coming from it. So maybe the low pressure light is the winner.
Old Mar 8, 2008 | 12:00 AM
TOM R's Avatar
think you are correct, i got a alarm light on the dash and no aftermarket alarm, as you can see in the pic there is a butt connector on the sender just no wire, i will have to look into this more tommorow thanks
Old Mar 8, 2008 | 12:11 AM
JPR Ram's Avatar
If that is what it is, hook one wire from the sensor to the led, and the other lead on the led to a 12 volt source. Then you'll be good to good.
The Domie
Mar 16, 2005 05:10 PM
Hondo
Dec 21, 2004 06:37 AM
ViperSBT
May 21, 2004 07:41 PM
moneypit
Aug 20, 2003 08:49 PM
