Unhooked banks box and now boost sensor code
Old May 12, 2010 | 03:11 PM
95black2615's Avatar
Unhooked the banks big hoss level 3 box to diagnose some engine problems and now check engine light is on with this code:
P0237 boost sensor input low
Truck has no power now.
Old May 12, 2010 | 06:53 PM
nickg's Avatar
you unplugged the box but did you hook the map sensor wire back into the map sensor..
or you might be making enough boost (over 22psi) and the truck will defuel
Old May 14, 2010 | 09:38 PM
Thanks for the reply. I don't have a clue how these boxes are hooked up. This was all added before I got the truck. I just took out the box completely, but didn't do anything with the wires.
Is it just simply unplug the wire from the box and plug back into the map sensor....or will i need to splice back into the original wires
Old May 14, 2010 | 11:03 PM
nickg's Avatar
not falimiar with the banks set up but most boxes plug inline, meaning your gonna have to find the other end of the factory wire and plug it into the MAP sensor, other wise the truck will code and defuel
Timmer
Mar 23, 2011 03:27 AM
sallyman1
Feb 17, 2008 04:54 PM
1998dodge
17
Apr 19, 2006 08:26 PM
mx261
Sep 26, 2005 04:54 PM
ddk
Nov 19, 2004 11:36 PM
