waste gate unhooked???
Old Sep 20, 2005 | 12:01 AM
mx261's Avatar
I thought id try it so i unhooked my waste gate and plugged the line. It seems to really pull alot harder now but I just want to make sure that it wont damage anything. If so ill fix it and go sit in the corner!! let me know what you guys think, thanks!
Old Sep 20, 2005 | 01:17 AM
got...DIESEL?'s Avatar
with that plate full forward it will help to get the boost up from 17 that's for sure. I however would curb my appetite until a pyro and boost gauge live on the pillar! You're better off with more boost than without as far as temps go, but you're really flying blind. Other than that no, you're not hurting anything, but join your local support group now, as the diesel 12 step program is impossible to stay on.
Have fun and get some instruments!
Old Sep 20, 2005 | 10:48 PM
Sidewinder's Avatar
I have mine disconnected and plugged. I have a #10 (full forward) with a 3000 GSK and a gutted cat - everything else stock.
With the wastegate connected I could get around 18 PSI of boost. Now with no wastegate I can get 30 PSI. My EGT never goes above 1100 Deg. but I wouldn't assume yours would be the same.
Old Sep 21, 2005 | 12:54 AM
mx261's Avatar
hey sidewinder, i noticed that in your sig you mentioned your cat is gutted. I wasnt aware our year (94-95) trucks had cats? just curious
Old Sep 21, 2005 | 09:47 AM
infidel's Avatar
1994 models built from July 1993 to January 1, 1994 DO NOT have catalytic converters, all later 12 valves do
Old Sep 23, 2005 | 08:43 PM
Sidewinder's Avatar
YEP!
The 12 valves have a cat stock. I took the pipe off between the cat and the muffler and used a combination of a hammer, wrecking bar and hammer drill to break-up and remove the insides of the cat. It has a sort of honeycomb, ceramic type of material insde. After removing it all it seems like I really didn't need to after all. It was completely clean inside and not plugged at all!
Oh yea, don't tell anyone it's empty!
Old Sep 24, 2005 | 07:14 PM
TxDiesel007's Avatar
My question with this would be
OK you plug up the wastegate, HOW DO YOU KNOW, you are not producing more boost than the stock 35 turbo can handle? I peg my 30PSI boost gauge oh so quickly that i dont like to keep it there too long, since my egts are post turbo as soon as they hit 950-1000 i lay off the throttle..
I have thought about plugging the wastegate, but is the proper amount of boost supposed to be known? i cannot afford a new turbo, nor do i know where my turbo is currently wastegated at.. I know the first step here is to upgrade my gauges.
what is the easiest way to set a wastegate on a 12V? adjustable elbow? if so someone please explain..
Tx
Old Sep 24, 2005 | 07:22 PM
CTD2001's Avatar
What method did you use to plug the wastegate line, i am thinking about doing this to my turbo to see weather or not my wasted gate is set to open lower then i think or if i have some type of a boost leak, thanks
Old Sep 25, 2005 | 01:16 PM
J BODY's Avatar
CTD2001, with all the mods you have I can't believe you haven't turnbuckled that wastegate yet. The turnbuck is cheap and easy for the 01 auto equipped trucks.
Old Sep 26, 2005 | 04:54 PM
CTD2001's Avatar
I dont have the stock turbo anymore, i have the holset super 40 turbo, that was why i was wondering about how to plugg the wastegate line
95black2615
May 14, 2010 11:03 PM
sallyman1
Feb 17, 2008 04:54 PM
1998dodge
17
Apr 19, 2006 08:26 PM
ddk
Nov 19, 2004 11:36 PM
