Unfasten negative battery to reset computer,,, how often?
Old Jun 24, 2005 | 04:35 PM
Tommy93w350's Avatar
Does anyone unfasten thier negative battery terminal so the computer would reset needed or not. I used to do this to my old 454 gasser after running fuel injection cleaner through it. It makes a significant difference in performance and mpg, until the the next reset.
I was wondering if the 01 diesel would do the same.
Old Jun 24, 2005 | 09:39 PM
dezlsmkr's Avatar
I dont think this works on one of these, i know if you have a bad code, like the check engine light is on ect, after you fix the problem the computer will reset the problem after so many starts.
Old Jun 24, 2005 | 09:49 PM
Supermod56's Avatar
The old tried and true method of disconnecting the batteries to reset the computer doesn't work on "OBDII" computer systems, normally you reset codes with a good scan tool, or like stated above it will reset itself after several starts. on the 01 you can cycle the key to the "on" position 3 times, and leave it in the on position the 3rd time and check for codes on the odometer read out. If you have no codes, don't worry about it.
Tom
Old Jun 24, 2005 | 10:01 PM
Mopar1973man's Avatar
There is a fuse in the power distribution box under the hood. You can pull the fuse for the ECM and do the same thing without killing the whole truck. (Clock, radio settings, etc)
It will reset codes but if there is still a problem it will trip the code again.
As for changing the performance... The only thing I can thing of is a APPS reset...Which is requiring a disconnect for 30 minutes...
bigjohn92
Apr 24, 2013 03:49 AM
pwregan
14
Feb 5, 2012 09:11 PM
GasganoFJ60
Oct 21, 2007 11:02 PM
Ram1
May 16, 2005 02:07 PM
