u-joints
Old Mar 10, 2008 | 07:27 PM
southerman's Avatar
u-joints
what is the proper way to check your u-joints and driveshaft, to see if they are still good.
Old Mar 10, 2008 | 07:55 PM
pull-do's Avatar
I usually put my transmission in neutral, crawl underneath, and work the shaft (rotating) back and forth while watching the u-joints for unusual movement, also for "noise", clunking------ just make sure you can differ from slack in the pinion and movement (clunking) in the joint/joints, it's usually pretty obivious, just do it slowly and watch and "feel" closely.
Old Mar 11, 2008 | 12:07 AM
dozer12216's Avatar
With wheels off ground so can rotate through complete revolution may give better feel of joint condition.
Old Mar 11, 2008 | 08:31 AM
pull-do's Avatar
Thank you--------- my bad------ "old" timers kicking in on my part.
kprc51
Jun 14, 2007 06:27 AM
njmaier
15
Jul 26, 2006 07:43 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
Dynocon
Mar 5, 2005 06:24 PM
