U joint gurus
U joint gurus
OK guys. When backing up in first gear I am getting a creaking noise oscillating with rpm and tire speed. I thought it was my e-brake, brake pads, etc. but after tearing everything down and finding nothing I still have the noise. I don't think its a bearing.
It seems to be coming from under the middle of the truck but is really hard to tell. I was sure it was the drivers rear disk caliper but now am thinking u-joint.
Thoughts? Thanks, Kurt
inspect the U-joints if you see rust colored dust near the joints they are done like dinner, you might not find them loose (as the needles pile up, tightening the joint) but if you remove the drv shaft and rotate the u-joint thru its range of motion I promise if a joint is bad you will find it by this method, rarely is it the joint closest to the transfercase, almost always its the one closest to the rear diff that goes first (it recieves the most articulation)
72dart
Jun 19, 2012 10:42 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
