Typical fuel pressure?
Old Dec 1, 2005 | 07:56 PM
jj3500's Avatar
gentlemen,
in our trucks, what is the normal cruising @ 65-70 mph fuel pressure suppose to read...flat road, no load, just simply cruising.
thanks
jj
Old Dec 1, 2005 | 08:09 PM
Mopar1973man's Avatar
I show about...
16 PSI with a starter bump
15 PSI at Idle
All these numbers are in 5th gear. (top gear)
13 PSI at 45 MPH
12 PSI at 55 MPH
11 PSI at 65 MPH
6-7 PSI WOT
These are rough numbers... This will change if the truck is cold and first started it will be lower. Once warmed up the numbers rise to whats listed... This is a stock LP pump... Not a FASS or other high performance pump...
Old Dec 1, 2005 | 08:58 PM
blackdiesel's Avatar
Registered
heck, i peg my 15 psi guage and i can only get it below 14 psi when i floor it. and i mean FLOOR it. i jsut installed a holley blue pump and im very pleased.
Old Dec 1, 2005 | 10:04 PM
HOdiesel's Avatar
Yes I miss my holly blue, I mistakenly thought the pump was going bad and I replaced it with a carter pump . The carter only gives me 11 psi at idle (9 WOT). My holley gave me 15 at idle and 14 psi at WOT. I'm still thinking of putting my holley blue back on My problem was the gague was going bad
Hodiesel
Old Dec 2, 2005 | 08:27 AM
Ph4tty's Avatar
My relocated carter gives my 15+ at idle (my guage is 0-15) and never drops past 12. Takes a couple seconds at WOT to get it under 13.
Old Dec 3, 2005 | 12:55 AM
TNutcher's Avatar
Hey,
Mine was going bad and would suck down to 6 or so at WOT but at about cruising w/stock setup I remember it being about 9 or 10?? i think somewehre around there! Roll On
TNutcher
tyssniffen
Feb 17, 2006 10:26 AM
Cummins600
Sep 21, 2005 07:41 AM
thecatsfan
16
Jun 20, 2003 10:36 AM
ouchman
May 2, 2003 10:07 PM
