Two Stroke Oil Update
Old Oct 22, 2006 | 06:11 PM
  #31
Mopar1973man's Avatar
Originally Posted by emoryemt-i
what is the deal with the 2 stroke oil you guys have caught my attention. i have 137k on my truck and will do anything to make the vp-44 last longer. is this practice safe or will it harm the truck in the long run. i work in ems so i dont make lots of money so i dont want to do anything to harm the truck..
In post #26 the Chevy 6.5L I'm talking about is the FIRE TRUCK I drive! It the only way to keep that beast running right... Other than that it trips the SES Light and reduces the power by half!
Old Oct 22, 2006 | 06:15 PM
  #32
Originally Posted by iker42
2 things...
1. Black or Synthectic 2 stroke?
2. Just dump it in the fill tank beofre pumping so it mixes?
Mike
1. I would go with 2 stroke oil over black (WEO)...
2. Yea... Just dump in your quart and fill the tank (20-25 Gallons)... You'll hear the difference in about 5 miles.
As a matter of fact I dumped in 1.5 quarts this morning. I forgot to add it with the last tank load... Boy it got quiet... The Cummins is going WEEHAW!
Old Oct 22, 2006 | 06:40 PM
  #33
Smooshy's Avatar
I've been doing this in diesels for 12 years since I owned my 6.2 diesel Blazer that I bought from my old man.
Old Oct 22, 2006 | 08:07 PM
  #34
gmctd's Avatar
You on any 6.5 forums, mopardude?
Old Oct 23, 2006 | 07:57 AM
  #35
gmctd's Avatar
Mopar1973man, Mr Roberts....................
Old Oct 23, 2006 | 09:04 AM
  #36
I guess you got to becareful of what you post you might get everyone posting a response to you post!
Which I've already answered in a PM... Maybe I soon of posted that... Oh Well live and learn...
Old Oct 23, 2006 | 08:29 PM
  #37
Beamwalker's Avatar
i ran 2 stroke a while and now i use 30wt non detergent every fill-up but will use 2-stroke if no oil available. power increase noticeable on my 1st gen and mileage back up. not much smoke either
Old Oct 23, 2006 | 08:58 PM
  #38
boostjunkie1's Avatar
I have about 5,000 miles on my truck now and at around 3500 miles I tried to use 16oz of 2cycle oil from Walmart (Ashless) and half a bottle of Power Service- - - - - - - the truck ran slower/felt like it had less power, puffed black smoke, and got worse mileage?????? What is the deal? I'm considering running the 2 Cycle oil by itself for a while and running the PS about once a month to clean the injectors. What do you all think?
Old Oct 23, 2006 | 09:10 PM
  #39
biglar's Avatar
After only a few days of this, I can't call myself a pro, and why it seems good in some, but not in others. However, I did read another thread in the archives where someone made the point of the outboard oil being designed to burn, and burn clean. Motor oil is said to be designed not to burn and will leave more deposits. True ?? I dunno, but it makes sense to me, and I think I'll stick with the outboard oil.
Lar.
Old Oct 23, 2006 | 09:46 PM
  #40
Tate's Avatar
Whats so great about the outboard oil? Wouldn't any 2 stroke oil be designed to burn, regardless of what application its in?
Old Oct 23, 2006 | 09:55 PM
  #41
johnh's Avatar
that's a good question, i have never tried just 2 stroke oil...it will probably work just as well. when i run out of what i have i'll try some
Old Oct 24, 2006 | 08:37 AM
  #42
RustyJC's Avatar
Ashless 2-cycle oils are just that - they have a sulfated ash content well below 0.1%, and sulfated ash is what's left behind after the oil is burned off.
4-cycle diesel engine oils typically have a sulfated ash level of 1.0% or higher, so they would leave behind over 10 times as much deposit as an ashless 2-cycle oil.
Rusty
Old Oct 24, 2006 | 08:48 AM
  #43
RowJ's Avatar
Yup!
Top quality oil companys make two types of 2-cycle oil.... liquid cooled 2-cycle oil and air cooled 2 cycle oil. Easier & cheaper to make air cooled 2-cycle because cylinder head temps are higher so the oil burns more easily.
Many more additives in liquid cooled 2-cycle oil (rated TCW-3) to make it burn more cleanly at lower cylinder head temps.
Since diesel engines have much higher cylinder temps than 2-cycle motors, I think either type of 2-cycle oil would work well, if your inclined to add that sort of thing to your CTD. Either one is much better than engine oil, IMO.
RJ
Old Oct 24, 2006 | 11:10 AM
  #44
megajoltman's Avatar
Originally Posted by REF>Lancer
The only way to make my truck as quiet as I like is to shut the thing off!
what he said
Old Oct 24, 2006 | 11:31 AM
  #45
REF>Lancer's Avatar
I put my used engine oil in,seems too burn.
