Turbo Shaft Loose
Turbo Shaft Loose
??? ??? After checking my air cleaner I decided to check my turbo wheel and when I wiggled the turbo the shaft had some endplay, around a 1/16 in each direction. For something to spin so fast and have play does not seem correct to me. What do you guys know about this?
Re:Turbo Shaft Loose
If you do not find any marks where the wheel has rubbed on the housing it's ok. <br><br>You can also look on the holset website and download the repair manual for your turbo and se if it's within specs. <br><br>AlpineRAM
Some side to side play is normal on all turbos. Front to back play is a different story.<br><br>Pull the wheel over and spin it with your hand, if it doesnt bind or touch you are okay.
Leaky Gasket
Aug 14, 2008 07:17 AM
Mototrout
Nov 16, 2006 11:24 PM
HorseHauler
14
Sep 28, 2004 11:37 AM
