Turbo Mount E Brake
Old Mar 20, 2005 | 08:16 PM
Ram2Pete's Avatar
Turbo Mount E Brake
Here is one of my questions I put up on another board so i was wondering what you guys thought
"I just picked up a turbo mounted pac brack for the HX-40 size housings and was wondering what other turbos use this same exhaust connections. the only thing missing is the air cylinder and I do believe it is off a motorhome or simular truck
Ok to get back to my question of which turbos could be used with this brake sence I'm going to be setting my truck up for more of a puller then a racer 400-450 for towing with mach 4 or 5's and ceteher and close to 5 with the drag comp. so with that said this is was looking at the B-1-EX4, B-1-2-tow from Piers and the airworks super from Rips insted of the HX-40 not that is a bad unit but I am thinking that these others might be a little stronger in the shaft department is there any others that I should look at and does anybody have any experience with the turbos listed. Or is this not posible with this brake. Thanks for any info."
Robert
Old Mar 21, 2005 | 08:48 PM
Ram2Pete's Avatar
no body has any info
Old Mar 22, 2005 | 08:59 AM
CTD NUT's Avatar
I'm not certain, but I don't think a HX40 elbow bolts onto a B1........The only turbo you can use that elbow on is a HX40 - to my knowledge..........BTW, is the brake you found a Jake?.......If it is, good luck finding a replacement air cylinder from them.......I have encountered some problems trying to get them from Jake......no apparent problems from the other E-brake suppliers.
Old Mar 22, 2005 | 10:28 PM
Ram2Pete's Avatar
its from pac brake
dieselfreak21
Mar 30, 2014 12:22 PM
J10495T
Sep 21, 2011 04:07 PM
chw
Dec 25, 2006 04:30 PM
12valve@heart
Aug 11, 2004 03:43 PM
belfert
Oct 14, 2003 12:20 AM
