turbo lag
Old Feb 18, 2008 | 08:05 PM
C Russell's Avatar
turbo lag
99 dodge 2500 4x4 having some jumping in boost gauge needle around 28 30 psi of boost ? could this be in the air to air bad gauge or turbo problems?
Old Feb 19, 2008 | 12:27 PM
pmtg's Avatar
could be wastegate flutter.
you have a snubber on it? or a needle valve?
does it do that at any other boost levels?
Old Feb 19, 2008 | 03:33 PM
NoSeeUm's Avatar
Thats not really called lag.
You still runing a stock turbo?
Jim
Old Feb 19, 2008 | 04:07 PM
C Russell's Avatar
yea still stock but put the brass fitting in the line. Done this when installed the edge comp thanks
Old Feb 19, 2008 | 04:11 PM
C Russell's Avatar
Im not sure what a snubber is or a needle valve that may sound bad?
Old Feb 19, 2008 | 04:31 PM
NoSeeUm's Avatar
Does it feel like the engine is missing at all?
Jim
Old Feb 19, 2008 | 07:07 PM
C Russell's Avatar
no just when you get it to these levels ?
Old Feb 23, 2008 | 05:00 PM
C Russell's Avatar
The snubber is in the block it is just a compression fitting. It feels like it cut out some.
Old Feb 24, 2008 | 07:11 PM
pmtg's Avatar
a snubber is just a fitting with a tiny hole (around an 0.008" diameter) that dampens the pulsations that can cause rattles. it goes inline with a pressure reading tube...fuel pressure, boost pressure. a needle valve can accomplish this too, you keep closing the valve until it is barely open...still allows a reading but dampens the vibrations. ive never had good luck with a needle valve, maybe if they made one with fine thread i could fine tune it better.
blueberry
Jan 11, 2006 12:46 AM
crossy
Jul 14, 2005 05:55 AM
ptextreme
Mar 21, 2005 02:02 PM
MY WORLD
26
Feb 26, 2005 06:47 PM
J BODY
Jun 8, 2004 07:16 AM
