Truck Stinks
Old Sep 8, 2004 | 06:01 AM
Minnesota-Corey's Avatar
Question Truck Stinks
Hello fellas. My question is my truck smells like an 80's diesel lately. I thought it might be fuel but I have ran many tanks through it with the same result. I hope this isn't some precurser to a majior problem. Grid heaters seem to be working. Any ideas would be appreciated. Thanks Corey
Old Sep 8, 2004 | 06:29 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Might be the refineries changing formulations.
You could always try this stuff.
Fuel Scents
Fuel Fragrances by Manhatten Oil
POWER PLUS CHERRY BOMB Fuel Fragrance is a unique product that is not only a proven crowd pleaser but a much needed item for many drivers that have a difficult time dealing with the nauseous odors of an alcohol fueled vehicle. Drivers that use POWER PLUS enjoy not only the pleasant fragrance but less irritation to eyes and nose and much more livable cockpit. POWER PLUS is the first of its kind creating a new category in fuel additives.
Delight the crowd with a pleasant smell. Try one of manhatten Oils 19 different fuel fragrances. They mask the smell of methanol and gasoline. Use 1 oz per 5 gallons of methanol and 2 ozs. per 5 gallons of gasoline.
ATOMIC APPLE
BANANA BLAST
BURN OUT BLUEBEERRYill
CHERRY BOMB
FLYIN’ HAWAIIAN
FULL BLOWN BUBBLE GUM
GROOVY GRAPE
LEMON LIGHTNING
LIGHT’EM UP LICORICE
PEEL OUT PINA COLADA
QUICK ET CHOCOLATE
RADICAL RACIN’ RASPBERRY
RIPPIN’ ROOT BEER
ROCKET COTTON CANDY
SUPERCHARGED STRAWBERRY
SUPER SONIC CINNAMON
TURBO TANGERINE
VICTORY VANILLA
WICKED WATERMELON
Old Sep 8, 2004 | 11:12 AM
RATTLINRAM's Avatar
Ed,,,,,
You spend WAY too much time on the internet!
Old Sep 8, 2004 | 03:17 PM
betsycam's Avatar
Hi Minnesota-Corey,
did you change oil recently? We did an oil change with Rotella, and it stank so bad afterwards, I actually posted to the forum to see what was wrong! One thing that I found out is that the rubber cowl that lines the rear of the engine compartment has a habit of falling down, and ours had - this allowed engine compartment fumes to get into the cab. I also read that Rotella is especially smelly!
betsycam
Old Sep 9, 2004 | 12:19 AM
McGyver's Avatar
I extended my blow-by tube after my "breather bottle" fell off the truck. There is a lot of vibration on the 5.9L
A hose is seen from the front of my truck, hanging down. The oily smell is gone from the cab now, and the front of the engine thanks me (it's not oily anymore)
Hope this helps. I can send photo's if you ask for them.
Cheers,
Pete
ps: Rattlin' Ram: DITTO! Shovelhead has been very helpful to me on several post's I must say!- but I laughed when I read your post! Thanks...
Old Sep 9, 2004 | 06:10 AM
Smell started before changing oil and the smell is coming from the exhaust and stinks as if it were an 85 chevy diesel in 10 below weather. I hope its coming from the refining of the fuel but I don't know. A better way to desribe it, is when you start a diesel and its cold generally the exhaust stinks. After warm up the smell will go away, but not mine lately. I could drive for 2 hours and it still stinks. Hope this helps.
Old Sep 9, 2004 | 10:39 PM
McGyver's Avatar
Sounds like an exhaust leak. Are all of the clamps tight/leak free under the hood?
Old Sep 10, 2004 | 07:48 AM
Homestead's Avatar
This is how you change the smell of diesel fumes!! Time to start drinking boys!! LOL!!
http://www.ananova.com/news/story/sm...ceanddiscovery
Old Sep 10, 2004 | 04:00 PM
ironman's Avatar
Stinks
I noticed after bombing my truck the exhuast smell became a lot stronger for diesel. Smells like a truck running rich.
Old Sep 13, 2004 | 12:26 AM
jimjawz's Avatar
The exhaust on mine is a wonderful rich blend of horse power and torque topped off with a pinch of hot and stinky. I love the smell of cooked diesel.
Old Sep 23, 2004 | 01:18 AM
horsappl's Avatar
Mine stinks too. I have a crack in the middle of the exhaust manifold.
Old Sep 26, 2004 | 02:00 PM
McGyver's Avatar
Homestead,
When I get up on a stool to pee into my tank, the hole is too small for "it" to fit . The only thing that I can think of is to use a funnel?
Any suggestions?
Pete
Old Oct 1, 2004 | 01:44 PM
roadranger's Avatar
Any suggestions?
Pete
Yeah, quit rubbing it so much!
Old Nov 8, 2004 | 07:21 PM
McGyver's Avatar
Ha, Ha... I guess I left myself opened for that one.
Old Nov 11, 2004 | 08:54 PM
CoastalDav's Avatar
If you have white smoke warming up, and heavy black smoke or white/black smoke when hot and still have the smell, you might have an injector problem with to much fuel in one or more cylinders. The VP44 could be out or the computer could be not working properly for that cylinder. Have you lost fuel mileage?
I would get a Vis Guage and check for fuel in the oil. That would tell tale of a leaking injector.
I more likely think its a computer problem.
Nothing smells better to me than a old GM 71 seris engine starting in the morning. White smoke and smell everywhere.
Dave
