Truck Shuts Off
Truck Shuts Off
The truck wont crank when i turn the key on and wait like 10 seconds. THERE is no wait to start light in till 30 sec. after ignition is turned to the run position. then it starts. if i turn it off after it starts and then turn it to the run position all operations are normal, BUT after 5 mins of idling the motor starts to shudder and will die if u dont give it some throttle, but still isnt running smooth by any mean. with the motor running and sputtering the odometer and the cab lights pulse (DIM-Bright) and when i let off the throttle it died, and has no power to anything. My question is could this be a dead comp?, or bad connection to the comp, maybe a main circuit breaker, if it has one. PLZ HELP ANYONE
Thanks, Logan
Thanks, Logan
i dont understand why nothing has power, i was thinking along the lines of ECM just for the loss of 12 volt power, but im open to anything, if its an injection pump, great that means it can be upgraded
SilverDollar
Jan 15, 2012 04:51 PM
rustydeeretech
Nov 1, 2010 08:56 AM
Tedonlin150
Jul 24, 2010 01:38 AM
Ozoneburner90
Jul 22, 2010 10:36 PM
