Truck died. Need help on codes
Old Aug 11, 2007 | 02:40 PM
vikingsven's Avatar
My 01 died yesterday on the freeway. No warning at all.
I got a code scanner and pulled:
P1693
P1689
P1688
P0253
Fuel pressure is 14 at the pump, so the LP is good.
Disconnected the Edge EZ and returned to factory. No go.
From research it looks like a possibly fubared VP.
I also noticed that the passenger side battery is toast. I went to disconnect it and the positive terminal pulled right out! It was corroded pretty bad underneath the terminal.
Would the battery account for any of the codes? All other wires and plugs look good. Nothing is burnt or damaged in anyway.
Old Aug 11, 2007 | 02:59 PM
blackdiesel's Avatar
Registered
1688 is the true death code of the vp44.
Old Aug 11, 2007 | 03:01 PM
vikingsven's Avatar
Would a faulty battery amount to anything?
Old Aug 11, 2007 | 03:02 PM
fschiola's Avatar
You can look up your codes Here.
Old Aug 11, 2007 | 03:11 PM
vikingsven's Avatar
Thanks. Doesn't look good does it?
Old Aug 11, 2007 | 09:01 PM
high country's Avatar
my 01' did the same, with similar codes......sorry about your luck
Old Aug 12, 2007 | 04:34 PM
vikingsven's Avatar
Thanks.
That's not the half of it though. Last weekend the motor in my 4Runner seized and the Tcase in my crawler munched the main bearing. It hasn't been a good week.
exwrestler
Feb 5, 2010 09:34 AM
RyanF
Dec 21, 2008 03:07 AM
Emoneysrt-6
Oct 21, 2008 11:17 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
