Trouble starting sometimes
Old Dec 10, 2007 | 03:08 PM
98.5CTD's Avatar
Here in the past 2 months, my truck has been having problems starting. The batteries are good so i can rule that out. I have a 5 spd. When i turn the key to the ON position, i can hear the LP run and everything, but sometimes when i turn to start it, it will just click (like the batteries were dead) and sometimes it will act like it will try to start and then stop. I turn the key off, let off the clutch, then try again. I can do this 2 to 3 times sometimes then it will finally start up. It doesnt do this all the time, maybe once every 4 or 5 times i try to start it.
Any ideas on what to even look at???
Old Dec 10, 2007 | 04:31 PM
2500Ram's Avatar
Starter contacts are the first thing that pop'd into my head. Try a search for starter contacts and I'll bet you'll find your problem. I believe you can get a rebuild kit for $35 or so.
Good luck.
Old Dec 10, 2007 | 05:58 PM
bandit408's Avatar
Check the clutch switch under the dash also.
Old Dec 10, 2007 | 06:57 PM
Copenhagenjunkie's Avatar
Agree with suggestions above but you might also check your positive cable terminals. At times I can got only a click, I know it's a bad cable terminal (over tightened it ) and now it's stretched but just haven't fixed it properly yet. I did insert a small screw between the terminal bolt and the battery post and that solved the problem I caused.
Old Dec 10, 2007 | 06:59 PM
Sorry bout the double post!
Old Dec 10, 2007 | 07:37 PM
daveg's Avatar
From: Colville,in beautifull Eastern (should be a state) Washington
If it's not bad batt. cable or clutch safety switch, it's likely worn solenoid contacts. You might see my post in "How Do I" section. daveg
Old Dec 10, 2007 | 11:19 PM
98.5CTD's Avatar
well, i cleaned the battery terminals really good this evening and it started right up. but it just kind of does it when it wants to. hopefully this could have fixed it. thanks for the suggestions though! at first i thought it could have been my clutch sensor
stanbnv
Jul 5, 2011 11:10 AM
The_Head
May 10, 2011 06:20 PM
Beast2B
Dec 8, 2009 01:44 PM
mr300x11
Oct 11, 2007 08:46 PM
Dave88LX
Mar 2, 2007 04:23 PM
