transmission fluid
Old Jul 2, 2009 | 07:13 PM
wesley64's Avatar
transmission fluid
what are the different types of atf that can be used in a 47re?can you use dextron or type f?i am in the process of rebuilding my tranny.
brett 2002 2500 4x4 diesel
Old Jul 2, 2009 | 08:02 PM
Gannetpeak1's Avatar
I had a rebuild with DTT parts done last year. My DTT transmission builder used ATF + 3, so that is what I use.
Old Jul 2, 2009 | 09:04 PM
Strong05's Avatar
Do a search on the forum, there should be tons of posts concerning trans fluids and additives.
Old Jul 2, 2009 | 09:56 PM
J.Suplanski's Avatar
Trans fluid
AMSOIL ATF + 4 works great good for 100,000 miles
Old Jul 2, 2009 | 10:24 PM
Mike D's Avatar
I run only merc/dex in my transmission.
Old Jul 2, 2009 | 10:30 PM
wesley64's Avatar
mike d,is that a gm fluid?dex stands for dextron,right?
brett
Old Jul 2, 2009 | 11:12 PM
Mike D's Avatar
I don't know if it a GM specific fluid. Mercon Dexron is the name and they list a couple of different applications on their label, I use the cheap advance auto stuff.
Old Jul 3, 2009 | 05:19 AM
dizzel's Avatar
Isn't factory spec ATF+4 ?
I thought that's what I saw on Gino's bullitins
yep here it is
http://dodgeram.info/tsb/2006/21-010-06.htm
LockedandLoaded
Jan 17, 2008 02:51 PM
Tommy93w350
Jun 26, 2007 04:42 PM
2500
Oct 2, 2006 09:14 PM
icrider
Sep 27, 2006 03:10 PM
