Transmission fluid
Transmission fluid
Where is the hole or cover that has to come off in order to drain old fluid? Where do I fill it with the new? How many quarts?
Thanks!!
Thanks!!
Bottom bolt on the PTO cover.....pull cover off and clean the magnet. Seal the PTO cover with some RTV and you are good to go.
Fill plug is 19 mm HEX (or possibly 17mm....can remember which). I believe its around 6 quarts.
I stand corrected - http://www.dodgeram.org/tech/transmi...5600_spec.html
9.5 pints (whatever that is)
LockedandLoaded
01-17-2008 02:51 PM
Tommy93w350
06-26-2007 04:42 PM
icrider
09-27-2006 03:10 PM
