Transfer case oil check bolt stuck
I wanted to check the level of the oil in the transfer case and the allen head bolt is REALLY stuck. I have put penetrating fluid on it and its been sitting for about 2 weeks and still no go. Any suggestions??? Would heating up the case around the bolt help?
If you have a small hand held torch just put some mild heat on it then remove heat and spray with penatrating lube, might have to do a couple of times but it worked for me. Make sure you coat it with anti-seize before you put it back in.
I found a little Teflon tape on the threads does the job of preventing leaks and it doesn't need to be tightened as much. With the case being aluminum and the plug steel I didn't like the idea of having to tighten really tight so it wouldn't leak and have the risk of cracking the case.
Thanks for all the info, I'll give it a try next week, have to help the sister move this weekend
, but motorcycle ice racing SUNDAY!!!! Little nervous about putting the 6600 lb truck on the ice... First winter with this truck... Sure love that Cummins motor...
Dave88LX
Aug 16, 2005 09:02 AM
justdirt
Oct 6, 2004 02:32 PM
