Transfer Case Capacity
Originally Posted by Marine
Drain it out in a measured pitcher, that will tell you.
phox
FSM says 4.61 pints of ATF+4, Chrysler spec 9602, and to fill to the bottom of the fill hole. So three quarts should be more than enough. Oh, torque spec on drain and fill plugs is 30-40 ft-lbs., which is a pretty loose torque spec.
"Tight enough that it doesn't leak" probably would have worked...
rmalone
Aug 21, 2008 07:35 PM
