tranny limit?
Old Nov 19, 2012 | 09:25 PM
bigsmokey's Avatar
tranny limit?
how much power can a 47re handle with just a triple disk converter and a valve body. I am not having any issues with it holding the power right now, but i was curious if i could do some 100 hp injectors and be ok, or should i get a fully built tranny first?
Old Nov 23, 2012 | 10:46 PM
KATOOM's Avatar
Its capable of holding decent HP but abuse and towing heavy are another situation. I'm not sure of the more accurate numbers you're wanting but getting a good torque convertor, new valve body, running a good cooler, and keeping the bands tight is about all I know you can do to keep that tranny happy.
Old Nov 29, 2012 | 10:05 PM
bigsmokey's Avatar
ok how often should you adjust the bands
Old Nov 30, 2012 | 05:03 PM
j-fox's Avatar
With bigger injector you will need a bigger turbo.
The weak links with the trans are the low pressure with a stock VB. You solved that.
Next is the weak stock converter, you solved that one too.
I NEVER recommend a 3 disc converter with the stock input shaft, so be warned.
Old Dec 2, 2012 | 11:17 PM
KATOOM's Avatar
I'm not sure. I dont have an auto so maybe someone with one can answer that for you.
coreydr2003
Feb 11, 2008 07:21 PM
wcbcruzer
Apr 2, 2007 03:48 PM
John H
Dec 1, 2004 03:29 PM
jt
Mar 17, 2003 08:44 PM
lunchbox
Nov 9, 2002 08:28 PM
