tranny fluid for power steering?
Old Jan 12, 2008 | 07:13 PM
safirenfish's Avatar
just got repair kit for vacuum pump seal from gould gear and electric, in the paperwork it says not to use tranny fluid for power steering pump or damage can occur- what are they talking about? i have had to use tranny fluid for ps pump in a pinch a couple of times as my steering gear box was leaking. what damage can happen? any thoughts on this
thanks bill
Old Jan 13, 2008 | 11:05 AM
dj_souvlaki's Avatar
the seals will swell.
Old Jan 13, 2008 | 11:56 AM
jrs_dodge_diesel's Avatar
Power steering fluid is essentially, hydraulic oil.
Tranny fluid is mostly light oil, with a bunch of additives thrown in, usually for the various components in a automatic tranny (clutch packs, etc.)
Old Jan 17, 2008 | 09:08 PM
dozer12216's Avatar
Chicken little says the sky will fall if you use ATF in PS.
Dodge silently changed to ATF+4 to keep # of fluids at assy plant to minimum. ATF+4 will work fine in PS. PS fluid orginally was slightly less flamable in severe failure on hot engine. Yes, some early hoses would swell when ATF used. Not seals in pump or gear. ATF+4 is far more heat tolerant than old PS fluid. The rest of additive package is harmless to The PS and hydroboost systems for many years back.
Common
Jun 9, 2008 12:16 PM
Tommy93w350
Jun 26, 2007 04:42 PM
BLK_RAM
Jan 18, 2003 10:14 AM
