tps location
Old Sep 25, 2004 | 09:20 PM
mooseman's Avatar
tps location
where is the tps located. ive read a tech. article about testing and adjusting the tps. i would like to try it to see if it helps with my shifting problems.
thanks in advance, mooseman
Old Sep 25, 2004 | 10:36 PM
cumminsdriver635's Avatar
On my 12 valve its right on the side of the pump where the throttle lever is. Im not sure where its at on a 24 valve, but my guess would be the exact same place. Ive adjusted mine a few times, and it makes a little difference. Good luck
Eric
Old Sep 25, 2004 | 10:53 PM
crobtex's Avatar
Are you speaking of the "APPS"? "Accelerator Pedal Position Sensor"?
On my '99, the APPS is under the black cover, on the drivers side, under the hood. According to Cummins, sensor is factory calibrated and requires the whole bracket assembly to be replaced.
If you figure out a way to adjust it, be sure to post the directions. It could save a lot of people a lot of $$$.
Old Sep 26, 2004 | 07:11 AM
mooseman's Avatar
(http://www.dodgeram.org/tech/transmi...TPS_adjust.htm)
this is where i found info on adjustment.
mooseman
Old Sep 26, 2004 | 07:21 AM
crobtex's Avatar
Mine is a 5 spd.
Old Sep 27, 2004 | 09:17 PM
Jetpilot's Avatar
mooseman,
The TPS adjustment is for a 12v truck not our 24v models....
Doug
whosdunit
May 17, 2014 08:54 AM
59FORD
Apr 7, 2006 12:28 AM
napa 600
Jan 20, 2006 02:57 PM
Hoss15
Jul 18, 2005 04:26 PM
warden
Jan 25, 2003 09:58 AM
