Towing; no power, high EGT and boost, terrible mileage
Old Sep 16, 2023 | 01:18 PM
SIXSLUG's Avatar
I occasionally pull and clean the IAT and MAP sensors on my truck but have never really noticed much of a change....
Your symptoms are smelling of fuel delivery issues I am thinking.... I can look in my fsm for a MAP resistance....stand by
Old Sep 16, 2023 | 01:21 PM
SIXSLUG's Avatar
Well apparently the FSM has a big section on MAP troubleshooting and the voltage varies between 0.5-4.5v across range monitored by PCM....
Can you get your hands on a FSM or download a copy?
Kurt
Old Sep 20, 2023 | 08:39 AM
Marine's Avatar
Veteran: Marine Corp
Kurt
I think I have a digital copy.
Are you saying that if it is out of the .5- 4.5v range to replace it?
Thanks,
Old Sep 23, 2023 | 04:36 PM
SIXSLUG's Avatar
That would be above my pay grade, but may be correct. I hate throwing parts at my truck, but after reading your thread thoroughly, I can't narrow it down any more than it has been.
Kurt
Old Sep 25, 2023 | 10:23 PM
Marine's Avatar
Kurt
I appreciate it.
Old Sep 26, 2023 | 07:55 AM
Greg Reed's Avatar
I had about the same problem with my 2002 pulling my 5th wheel to Montana. I checked all of the bakes on the truck and the 5th wheel with an IR gun. One of the brakes on the 5th wheel was very hot. Found a broken spring in the brake on that wheel. Replaced the brake springs and that cured the problem.
Old Sep 26, 2023 | 08:29 AM
Marine's Avatar
This is the second story like this. It is plausible but didn't you smell the hot brakes? I have had brakes stick before and there is a definite brake smell. I guess the best way to check is to pull them off and check.
Thanks,
Old Sep 26, 2023 | 10:52 AM
Thanks,
A temp. gun is your friend for finding brakes that are dragging easily.
Old Sep 26, 2023 | 11:10 AM
Greg Reed's Avatar
No, I didn't smell hot brakes on the trailer, even when I was checking the temp with the IR gun. The brake wasn't totally locked up. It was dragging enough to really pull down the power.
Old Sep 29, 2023 | 09:17 PM
Marine's Avatar
Ok good to know. I will hook it up when the rain stops and take it for a good pull, and shoot the brakes with a temp gun.
I'll update when I do it.
Thanks,
Old Oct 18, 2023 | 07:32 AM
Marine's Avatar
I hooked the trailer up, pulled it down the highway, and then checked the temps. 3 of them were at around 90 and 1 was at around 97. I don't think that is enough to be conclusive.
Old Dec 6, 2023 | 07:34 AM
Marine's Avatar
I bought and installed new Injectors. DAP 100HP PERFORMANCE INJECTORS 7X0.009 SAC. The injectors I pulled out look pretty carboned up, but I have not had them tested or inspected.
I'll be hooking up a trailer similar to mine on the 16, so I will see how it goes....
Old Feb 26, 2024 | 08:41 AM
Marine's Avatar
Ok All, I think I may have found the issue. Prior to my original post above, I brought it in to a trans shop to drain and fill and adjust the bands. Long story short, I brought it back again because the trans was getting hotter than it used to. I brought it back to the place, and he adjusted them again. Still getting warmer than it should. I brought it back (because he was going to fix it as it started acting up AFTER I brought it there) because he wanted to adjust the bands AGAIN just to make sure all was ok, and he found the cable spring was not attached.
SO....I have to wait to hook up the trailer to see if that was the cause of my symptoms listed above, but it sounds like it could have been.
The bad part of all this is I have driven about 5000 miles like this. Not good on the transmission for sure.
I am still on the lookout for a boost tester, but I am optimistic about the trans issue being the culprit.
Thoughts?
Thanks,
Old Dec 15, 2024 | 10:00 AM
Marine's Avatar
Thoughts?
Thanks,
Update: the shop built and paid for a new high performance transmission.
Old Dec 15, 2024 | 10:26 AM
Thanks for the update.
Glad it worked out for you.
