today was an eventful day
So today I put my new ball joints ( moog ball joints
) both sides upper and lower and man they were freakin stubborn to get out!!!! it took me 6 1/2 hours today to replace all four ball joints, both wheel bearings and axle seals
....... I'm glad i'm done with that project
now its time to kick back and have a couple beers
now its time to kick back and have a couple beersDon't forget to get a wheel alignment now (unless you are going to replace other parts still).
This and those free mirrors..... times like this just don't happen every day.
6 1/2 hours is pretty good for all that. Mine took a whole weekend to do 4 balljoints, a tierod end, tranny and t-case output seals, both rear wheel seals and one bearing, driverside front hub, replace all drivetrain fluids, adjust parking brake shoes, and replace front pads and rotors, and front axleshaft u-joints
And to top it all off, the pass. side hub nut pulled the threads off my stubshaft with it, so I had to take that to a machine shop to get repaired.
You shouldn't need to do a front end alignment if you only did balljoints. If the camber is off, theres not much you can do about that. I guess it wouldn't hurt to check caster though. If thats off way to far, it can actually wear your balljoints out prematurely.
And to top it all off, the pass. side hub nut pulled the threads off my stubshaft with it, so I had to take that to a machine shop to get repaired.You shouldn't need to do a front end alignment if you only did balljoints. If the camber is off, theres not much you can do about that. I guess it wouldn't hurt to check caster though. If thats off way to far, it can actually wear your balljoints out prematurely.
2500TurboDodge
Apr 7, 2005 01:49 PM
