Tire size question
'02 has a slightly wider dually offset than previous years. You can fit 265/70R16's, which is a slightly smaller but wider tire. But I wouldn't recommend that size at all -especially if you're towing or carrying loads. You can fit 255/85R16's - I've run them without problems - but unfortunately that size is no longer available in a load range E - only in D. The only exception seems to be the Toyo M55, which are hard to get, costs about $225 each, and - frankly - made by a company that doesn't have the best reputation.
Otherwise you're pretty much stuck with the standard 235/85R16's unless you want to buy expensive space adapters or do some modifications and go up to 17 inch rims.
bigdogtruck
18
Nov 21, 2007 08:09 PM
mkeanglorldo56
Nov 4, 2007 12:34 PM
4RnrRick
Feb 27, 2007 11:25 AM
