there she goes
Old Aug 19, 2004 | 01:38 AM
wgingg's Avatar
there she goes
well after a little buckin and snortin i got her 175 miles home and threw a p0216 and a p0230 which seems to mean my vp died. ive only got 40,000 on it and wondered about advice when i take her in. i know its warrenty but just want any advice or experience that will help me with the tight fisted local dealer. does that code mean its bad for sure or that theres just a problem? ive been going to get gauges but havent gotten around to it since ive got 60000 miles to "play" with but ill get em soon. thanks in advance for any help
Old Aug 19, 2004 | 06:45 AM
HOHN's Avatar
IT sure SOUNDS like a VP, whether it is or not.
This should be an easy warranty repair.
Old Aug 19, 2004 | 05:23 PM
wgingg's Avatar
they said theyll warrenty it with out a fuss IF thats the problem. just waiting for them to get to it!
Old Aug 19, 2004 | 07:52 PM
wgingg's Avatar
well they replaced the lift pump and said since the vp cleared itself it was fine. dont know but seems to run fine and i need it this weekend soooooo its way better than a stick in the eye!
Old Aug 19, 2004 | 10:21 PM
phox_mulder's Avatar
You now have documentation that the lift pump was bad an replaced.
Now, down the road if you lose your VP44, you can say "well, you replaced the lift pump xx months ago, why didn't you just replace the VP then, especially since it was throwing codes?"
phox
Old Aug 20, 2004 | 01:52 AM
mamm7215's Avatar
Well....
Keep your eye on your VP44. I hate to say it but from personal experience, it's gone. P0216 says fuel injection timing failure but it means the electronics in the pump is shot or going soon. Hate to say it but if it's under warranty, get it done as soon as possible.
Old Aug 20, 2004 | 04:22 AM
Barry Smith's Avatar
Mamm, is right! When I lost mine it took the VP with it. They say without the lift pump it runs the VP dry burning it up essentially. When they replace your VP it will be with a remanufactured pump so Run the H**l out of it when you first get it back. When I got mine back I installed my PM2 on it and took off up the enterance ramp at WOT and didn't make it to the top. They replaced it and this one has been good. Knock on wood!!!!!!
Old Aug 20, 2004 | 02:37 PM
wgingg's Avatar
they warrenty your vp with a reman??!! that seems kinda idiotic! i thought it was odd not to do the vp at the same time but i got another 60000 miles of warrenty. thanks for the info guys
Old Aug 20, 2004 | 03:00 PM
MCummings's Avatar
Most 216'd VP's I've seen, and have been "cured" with a new LP, have failed within then next 14 days...
Keep your eyes peeled for hard start when hot, dead pedal, blue smoke (out exhaust) and miss-firing.
Merrick
Old Aug 20, 2004 | 07:41 PM
Cummnzpowr's Avatar
Ditto on what Merrick said...i had those symtoms for about 1 solid month then eventually the truck would hardly run anymore..
Old Dec 8, 2004 | 01:10 PM
HaulinBut's Avatar
I feel like such a dunce........But......what the heck is a "VP"?
Old Dec 8, 2004 | 01:49 PM
Mcmopar's Avatar
The injection pump
Old Dec 8, 2004 | 04:12 PM
wgingg's Avatar
shes still going! ive been to montana and back 2xs with no trouble. ive been thinking to get some lucas treatment but figured then it will last till 100,001 miles so ive put it off hoping it will die
Old Dec 8, 2004 | 05:39 PM
BigBlue's Avatar
Be sure your driving the snot out of it. Beat on it hard.
Old Dec 10, 2004 | 02:08 PM
awmasparky's Avatar
My VP went for another 50K after the LP replacemnt. Not covered, cost me a small fortune to replace the VP. Next time I will try to do it myself.
