In tank pump
Old Feb 1, 2007 | 01:37 PM
ib516's Avatar
I have truck in sig with the in tank pump that Dodge bought and paid for. I can't get below 5psi at any time, pressure is good. That said, my truck also has the Scotty kit on it, which eliminates the banjo bolts. Scotty is out of business now, but Vulcan makes a similar kit.
All 2nd gen trucks need a way to monitor FP, need a big line kit, and shouldn't have any banjo bolts IMO. No FP issues here at all, even when held at WOT to illegal speeds.
Old Feb 1, 2007 | 05:33 PM
Sixpack's Avatar
Originally Posted by lsgibb
oh man that sucks, but even more so if you had to pay to replace a bad VP44, when other 02 owners are getting theirs replaced for free.
Check with a dealer as to what your "in service date" is. Mine is an 02 and expires 5/13/07.....
Old Feb 1, 2007 | 09:54 PM
J BODY's Avatar
I've installed a bunch of in-tank pumps in the 2nd and 3rd gen trucks. Haven't had a prob with any intank pump on the diesels......yet.
Old Feb 2, 2007 | 07:33 AM
ohiostate24's Avatar
Would the intank pump push enough pressure for an Edge EZ or a smarty? Maybe its just me, but that doesnt seem to be a lot of pressure.
Old Feb 2, 2007 | 08:21 AM
J BODY's Avatar
My lift pump is at 10-12 idle, usually 9 around cruise, 4-6 under heavy throttle. Some here would consider that "low psi", but I feel there is no prob with it. If you saw the orfice size where the return line goes on a VP you would see you are not going to get alot of fuel return.
Old Feb 2, 2007 | 09:23 AM
lsgibb's Avatar
No problems with my Smarty on level 9 all the time not even when pulling my trailer.
Old Feb 2, 2007 | 09:37 AM
scook6's Avatar
You must check you in service date. The last 2002s came with a 7yr and 100,000 mile warranty. I know this because that is when I bought my truck which I still have. This was done at the end to clear out all of the remaining stock of second generation trucks.
2002 2500 Q/C 4X4 "Short Bed"
Old Feb 2, 2007 | 03:16 PM
vrj's Avatar
vrj
I had the in tank pump put in last summer and was at 8psi idle and could suck it down to 0 WOT with just the Smarty. I then installed the Vulcan big line kit to help the in tank pump and now I am running at 9psi idle/cruising and about 6psi WOT.
My lift pump when south 2 mos. ago and the dealer installed the in-tank retro kit.
A couple of weeks ago I installed Vulcan fittings with 1/2" line from the metal fuel pipe on the frame rail to the VP44. I also installed a fuel pressure sender at the VP44.
My fuel pressure gauge is showing 9psi idle and 6psi WOT. This weekend, I'm going to add a Holley pump on the frame rail along with a Racor fuel filter/water seperator.
Also, I'm currently getting approx. 17.4mpg!
TJE
Oct 25, 2006 10:21 PM
Mike M
Jun 5, 2006 11:38 AM
ddestruel
Mar 26, 2006 01:54 AM
Toby
Apr 6, 2005 12:31 PM
2500CTD
Feb 27, 2005 01:29 AM
