tach pulsating
Old Nov 9, 2006 | 07:57 AM
eflynn1959's Avatar
tach pulsating
My tach just started pulsating when I apply the brake pedal. idles at 800 in drive in neutral with brake on it idles pulsates between 800 to 850 2001 Dodge Ram ( auto) all stock but exhaust
Old Nov 9, 2006 | 08:04 AM
moneytlks01's Avatar
mine does this also, just wondering whats the cause??
Old Nov 9, 2006 | 08:27 AM
jrs_dodge_diesel's Avatar
What you guys are describing sounds a lot like the "bouncy tach needle". If the needle is simply bouncing a little, but there is no audible change in the sound of the engine, and it is running smooth, then you have nothing to worry about.
The CPS (cam or crankshaft position sensor) senses the RPM's. The output of that goes to the ECM, which in turn feeds the tach. Essentially, its an analog signal that gets converted to a digital signal (in the ECM) and then changed to whatever the actual guage requires. Also the sensor itself is a magnetic sensor, attached to the crank (or cam) shaft is a magnet that creates a pulse in the sensor as it swings around.
A lot of 24V engines have the bouncy needle, including mine. Just the nature of the 24V.
Old Nov 9, 2006 | 09:19 AM
Mopar1973man's Avatar
Yeap! Jr got that right...
Cam sensor...
Old Nov 9, 2006 | 04:18 PM
ok, sounds fine to me, was just wondering...thanks
mamm7215
Oct 14, 2005 12:06 PM
sammy340
Oct 22, 2004 01:25 PM
sneilan
Aug 16, 2004 09:21 AM
sneilan
Aug 15, 2004 09:33 AM
vtailflyer
Aug 4, 2004 11:31 AM
