tach going dead
Old Dec 12, 2007 | 10:23 PM
JackRAK's Avatar
tach going dead
I have been having an intermittent problem with my tachometer dieing. The check engine light will turn on and after a while the tach will return to normal. After a few cold starts, the light will go out, so the code must be clearing periodically. The truck runs, and the speedo, gauges, charging system, A/C, etc all work fine with or without the tach. Sometimes it does it on a hot start, tonight it did it just driving down the road. Power with or without tach seems fine. Mileage is great, I am getting 23 mpg in mixed driving. I haven't pulled any connections apart - yet. I am thinking it is the Crank position sensor, as I have always had a lumpy idle, especially when hot. Looking for some ideas, before I do anything drastic.
Old Dec 12, 2007 | 10:32 PM
gator6's Avatar
cam position sensor?
been a while since i messed with 2nd gen but i think if the tach stops working the cam sensor under the vp44.
Old Dec 12, 2007 | 10:43 PM
lotero's Avatar
crank position sensor, crank position sensor, crank position sensor. its a 10 minute job.
Old Dec 12, 2007 | 10:56 PM
torquefan's Avatar
I've diagnosed a couple VP44 equipped trucks with intermittent tach problems. Crank sensors were the culprit.
Old Dec 13, 2007 | 05:47 AM
mini14's Avatar
99's have a crank sensor, 2000-up dont, the crank sensor controls the tach.
Old Dec 13, 2007 | 10:38 AM
CoastalDav's Avatar
My truck had the CPS changed at 93K. The tacometer was eractic as well.
In service Date for my truck was Dec 99.
Dave
Old Dec 14, 2007 | 05:42 PM
JackRAK's Avatar
Thanks for the info. It seems the Crank Position sensor is worth the effort to just go fix. My ABS speed sensor died about 20K ago, so I am not surprised that this died at 118K. Now to find a cheap source.
Old Dec 15, 2007 | 09:55 PM
Mike Perez's Avatar
It's not a ten minute job, You need to remove the starter to get to the Crankshaft Position sensor on the 99' it'll take about a hour or so.
Old Dec 16, 2007 | 12:53 AM
daveg's Avatar
From: Colville,in beautifull Eastern (should be a state) Washington
No tach.
Mike Perez is correct. When the tach would cut out in my '99 i would loose some power. I replaced the cps a couple of years ago, it was about $75.00 at NAPA.
Worked fine since then.
Steve V.
Nov 30, 2008 03:10 AM
silverbullet02
Mar 15, 2007 05:17 AM
Tengu
Feb 13, 2007 08:39 AM
apache
Oct 29, 2004 09:54 AM
Paradise Racing
Jun 17, 2004 08:28 PM
