Swapping 47re with the nv4500?
Old Feb 5, 2008 | 05:46 PM
deiracer3's Avatar
I am thinking of putting the a manual trans in my truck. Who has done it? I was wondering what goes into doing this? I have an 02 ex-cab 4x4. Let me here your thoughts thanks!
Old Feb 5, 2008 | 06:24 PM
Sunir's Avatar
I just put up a very similar post...I am also considering this and am interested in any advice folks have...just subscribing to your thread.
Old Feb 6, 2008 | 08:33 PM
Redog76's Avatar
yea this sounds interesting anybody know anything?...
Old Feb 6, 2008 | 09:05 PM
ILLINOISRAM's Avatar
I DID THE SWAP IN A 97 2500 EXT CAB 4X4. IT WAS PRETTY EASY OVERALL, BUT THERE WAS A COUPLE OF TRICKY PARTS. THE FIRST ONE IS THE 241LD TRANSFER CASE HAS THE WRONG INPUT SHAFT RECIEVER FOR THE 4500 WHICH HAS MORE SPLINES. THE SECOND ON IS NOT REALLY HARD BUT THE DRIVE SHAFTS NEED CHANGED 1 1/2 INCHES IN LENGHT. THE THIRD IS CUTTING THE WHOLE IN THE FLOOR FIR THE SHIFTER. oN THE 97, THE 4X4 LEVER BOLTS THE THE TRANNY SO WE HAD TO BUY A DIFFERNT LEVER FOR THE SWAP. IT COULD BE MADE TO FIT THOUGH WITH A LITTLE WORK. OTHER THAN THAT IT IS NOT BAD. THERE ARE ALOT OF OTHER DETAILS I COULD TELL YOU BUT THIS IS THE HARDEST PARTS OF THE JOB. ____________________ TIM
Old Feb 7, 2008 | 09:05 AM
Southern Pride's Avatar
illinoisram, did you have to replace the whole transfer case, or could you just replace that shaft for one with 29 spline count?
Old Feb 7, 2008 | 10:31 AM
1-2-3's Avatar
Just a plain ole guy
I've thought about doing this with my 99, but I was concearned the computer would have an issue with not having some of it's inputs from the auto trans being there.
Old Feb 22, 2008 | 10:48 PM
Sorry it took me so long to get back here. I don't know if your still looking for a answer, but just in case you are, here it is.
Southernpride, no you do not have to replace the whole transfer case just the input hub. The tranny shop acually did it for me. They had a used one the was good. You could probably do it yourself.
Charliez, there is no problems with the electrical. The only thing i had to ask for help on was the proper way to wire up the cruise control and neutral safety switch. Which thanks th DTR, i felt like a once they told me how to do that.. Anyway, well worth it to do the swap. TIM
thehemikid
Feb 25, 2021 12:45 PM
LockedandLoaded
Jul 25, 2011 08:14 AM
Munchies
Oct 19, 2006 06:09 AM
dma251
Oct 28, 2004 01:38 AM
