stuck starter and...
Well I went over to my buddies house to sit around a fire for a bit so I could take a break from studying and I go to start my truck and the dern starter got stuck. I've had a hard start problem for about a week and I just usually do what I've been doing, try to start the truck once and if it doesnt crank like it should I just let the pump run and then it'll usually just turn right over on the second try. Well I did the same thing, turned the truck off but the dern starter got stuck on. I switched the key back and forth to see if it would turn off, but the truck cranked up about 6 or so seconds later. What the heck is up with that???????
Also the other day while I was tooling around out side I decided that I needed some tunes playing so I switched the key to where just the radio would come on and the lift pump started to run like it would if I had bumped the starter. What in the world is going on????
This sucks a big ol' injector cause I just got my tranny straightened out and now I got not tranny-related problems.
Probably your starter contacts gone. Like $2 a piece will fix it. Just do it yourself. I have a write up somewhere on kydtr. Ill try and find it for ya.
Eric
On Edit: Here ya go
http://kydtr.com/iboard/index.php?sh...arter+contacts
Eric
On Edit: Here ya go
As you might have guessed, mine did the same thing. What will happen now is your starter will start to make "click" noise when you turn the key and start after messing with it for a while and eventually it will leave you sitting. BTW....not fun pulling the starter at 10pm in a muddy dirt parking lot with no light. It happened to be that I had ordered the bigger contacts and new plunger but they had not got here yet. So, i found an old piece of copper tube and flattened it out with a hammer, cut it to length, bent it 90 deg. drilled some holes, cut and filed a radius to go around the middle contact and after cleaning everything else up inside the starter, put it back together and put it back in the truck and no more problems. Trust me, just go fostertruck.com and get the bigger ones, change them and get it over with.
Adam
Adam
The solenoid is rebuildable, the contacts are inside. You'll probably find that when you open up the solenoid only one of the contacts will be worn out. Are you driving you truck to Jax this weekend?
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
