strange FP problem
Old May 21, 2006 | 04:29 PM
piperca's Avatar
Originally Posted by chadwick
i was thinking that if the tank had vacuem wouldent you hear it depressurieze when you took the cap off. Or would it lose it vacume though the system when it is not running. Also i thought gas caps where made to only hold a certain amount of pressure
Everything you say is true. When I open my fuel cap, air rushes in for approximately 2-3 seconds, quite a long time! Even with the cap loose, the vacuum is causing the cap to seal. I checked it yesterday when I got home and pulled it away from the filler neck and heard a short hiss of air entering the tank ... not as bad as when it's screwed down. I don't know what is causing it, but I'm going to fix it!
Old May 25, 2006 | 09:30 PM
firehawk's Avatar
FASS is in, all is good. I started the truck right before I did the conversion to make sure I was still having FP problems and was. Installed the FASS and now have 16psi at idle and 14psi WOT. Money well spent. Thanks for all the input.
Old May 25, 2006 | 09:58 PM
johnh's Avatar
there is a vent on top of our tanks, i remember seeing a post on this subject. but i don't know how to find it....the module has a vent that may have a plug or a cap on it, remove the plastic cap and you should be good to go
dieseldel
Mar 12, 2007 09:50 PM
stucw
Feb 3, 2005 12:03 AM
terraj
16
Dec 21, 2004 07:04 AM
Mike D
14
Jul 2, 2004 09:17 PM
nancym
Aug 20, 2003 08:40 AM
