Steering Gear Box
Old Nov 1, 2006 | 12:17 PM
FD5's Avatar
FD5
Steering Gear Box
My 2002 has about 1"-2" of slack in the steering, are the steering gear boxes adjustable or do I need to replace it?
Old Nov 1, 2006 | 09:59 PM
the496rocket's Avatar
Yes, the gearbox is adjustable, and relativle simple to do, there is a 3/16 allen screw on the top with a 5/8 jamb nut around it, you can see it easily from under the hood, I find it easiest to adjust it laying on my back on the ground, loosen the jamb nut while you hold the allen screw from turning, when the jamb nut is loose enough, turn the allen screw clockwise a quarter to a half turn depending on how much play is in your steering wheel, dont go too tight or it will bind, if its not enough, turn it a bit more. Let me know if you got it.
Old Nov 1, 2006 | 10:30 PM
Geico266's Avatar
The Rocket has it right, but I would would only tighten it 45 -50 degrees at a time.
Old Nov 2, 2006 | 01:16 PM
eflynn1959's Avatar
Make sure its not the track bar giving you that steering box movement
04ctd
Oct 5, 2006 08:27 PM
unioncreek
Jun 29, 2005 02:00 PM
pwrtripls1
May 30, 2005 09:17 AM
wood_n_soldier
Jun 16, 2004 06:15 PM
Mr. Jimmy
May 6, 2004 06:17 PM
