starter removal
Old Sep 13, 2006 | 11:46 AM
kinser5mfan's Avatar
starter removal
this cannot be done by a man with large forearms!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i have fought it for 3hours trying everytrick from this forum and another one called two diesel mechanics and it is impossible for a large man to do this!!
Old Sep 13, 2006 | 12:14 PM
i did forget to say thanks to those who posted the tips in the first place ( my bad)
Old Sep 13, 2006 | 05:44 PM
GSP's Avatar
GSP
Are you pop eye the sailer man? Get a super model with skinny arms to do it. Kick back and have a beer and enjoy the view
Old Sep 13, 2006 | 08:40 PM
bentwings's Avatar
Wait until it is about 35 degrees out, rain and sleet, all by your self, middle of the nowhere , with only a small mag lite, with cold water creek running under the truck. Guaranteed you will get it off no matter how big you are.
The hot shower afterwards is something you will never forget.
Old Sep 13, 2006 | 10:17 PM
Tate's Avatar
I don't have large forearms, but that shouldn't matter. The hard one to get is the top bolt. Get a 6" extension on a 3/8" ratchet, with the 10mm socket. This should be just a hair longer than the starter, so you'll be able to swing the ratchet. Then work from underneat, snake the ratchet in there. Might take a try or two to get it in, but it will fit. I had the luck of removing it this way. Luckily, my arms are small enough to squeeze in through the top to put that bolt back in.
Old Sep 14, 2006 | 01:10 PM
GSP's Avatar
GSP
Like Tate said , Just use a 3/8 rachet and 6",8" extention and a 10mm socket. I have snap on extensions with the tappered male end so the socket can wobble. Dont thing you need that or a wobbly socket just a straight set up.
Its realy pretty easy to pull the starter.
I think it took me 15 minutes to replace mine
Old Sep 14, 2006 | 01:21 PM
bamadzl's Avatar
I wouldn't call my forearms small, and I had no problems. You must have HUGE forearms.
Brad
Old Sep 15, 2006 | 06:55 AM
coalburner400's Avatar
I had read somewhere that someone uses a bottle jack to apply the tq on a modified wrench (to get that top bolt).
Good luck with this. I have not replaced my starter, but I've been there with other impossible tasks. Someone got it in there, there has to be a way to get it out.
Old Aug 11, 2025 | 09:53 AM
stowaway's Avatar
starter removal
+i have a 2001 ram 2500. removed the three bolts and starter won't budge. tapped with hammer . no luck. anyone run into this
Old Aug 11, 2025 | 02:49 PM
You can try jacking off the floor with a block of wood on the jack or the like if you KNOW you have all the bolts removed.
Old Aug 12, 2025 | 08:51 AM
stowaway's Avatar
thanks for the info. 2x4 and a big hammer got the job done
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
Billfisher
Dec 15, 2002 07:32 AM
