Starter problems
Starter problems
I got off work tonight and went to start my truck. Turned the key and waited for the idiot light to go out. The truck cranked very slowly, and would not fire. I popped the hood and noticed the Negative cable was a little loose. Tightened it and tried to start it again. The engine cranked better but something let loose, and now the starter just spins and does not turn the engine over. I got some help and pull started the truck. When I got home, I shut it off and tried to start it again and the starter just spins. Any thoughts?
Starter gear has sheared off? Time for a starter rebuild or a new starter would be my guess.
Good luck with it. Make sure that you keep those battery cables clean and tight.
Cheers!
Mike
Cheers!
Mike
Sounds like starter removal is needed to diagose the issue.. Gear is gone or there's not enough amp to the starter to engauge it to the flywheel.
Checking your voltage at the starter isn't a bad idea at this point..
If there is not enough battery power to pull the solenoid core in completely and thus engage the pinion gear to the flywheel, would the solenoid contacts be bridged? Would not the pinion gear be pushed most of the way into the flywheel before the starter motor was energised and started to spin?
Possibly, I would check the batteries and work my way towards the starter from there. Cables/connections, starter bolts, voltage at starter trip wire and at lead, etc.
Ignition switch?
Then on to pulling starter, (10mm and a bendy arm!) and pull apart to inspect.
Cold in Toronto, eh? I would go to the batteries first....
Congrats on Hockey!!
Ignition switch?
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
