starter
Old Sep 14, 2012 | 11:39 AM
Twodiesels's Avatar
starter
Have to change the starter on my 2002. Its the original. Can someone tell me what size wrench I need, so i don't have to make 10 trips back to the tool box? I assume it's held on with 3 bolts.
Thanks.
Old Sep 14, 2012 | 01:27 PM
Silver R/T's Avatar
Why are you changing it? Is it clicking and won't start? It could be as simple as changing out contacts/plunger
Old Sep 14, 2012 | 02:34 PM
cowboykilla235's Avatar
dont change it, rebuild it!!!!! the re-man ones are chineese JUNK!!!
those things dont break...
but to answer your question i belive it is 10MM and there is 3 bolts
Old Sep 14, 2012 | 03:07 PM
patdaly's Avatar
10 MM, and MUST be a 12 point.
And yea, have it rebuilt by a reputable place or get one from Foster Truck. Rebuilds from the chain stores don't last.
Make it painful only once if you have to.
Otherwise you might be laying in the snow in January changing that Auto Zone reman.....
Old Sep 14, 2012 | 03:30 PM
Silver R/T's Avatar
Rebuild it yourself, get a kit off of ebay and you're set.
Old Sep 14, 2012 | 06:55 PM
iwhitne's Avatar
http://www.mean-green.com/
last starter you will ever buy
Old Sep 14, 2012 | 08:32 PM
Twodiesels's Avatar
Thanks guys. Has new batteries and connections are all clean. It clicks when I turn the key. I understand about the parts store starters. Replaced one on my other truck a few years ago, and it took a dump within a week. Ended up putting a nippendenso on it. Big difference.
I think I will have this one rebuilt.
Old Sep 15, 2012 | 09:00 AM
Homestead's Avatar
A set of contacts off Ebay, a 10mm wrench, 3 bolts and and not even an hour of your time and the clicky click goes away.
Just did it, easy job.
Jeff
Old Sep 19, 2012 | 02:35 PM
Twodiesels's Avatar
Got the rebuilt starter in. Man what a difference.
Only one problem, I poked a hole(not sure how)in the tranny oil line, it's about the size of a pencil lead. Two running side by side and its the one that connects into the back of the tranny to the left of the pan. I jb welded it for now.
What should I expect to pay for a new line if I do it myself? And how do the ends come apart where there clamped? Just squeeze them?
Thanks
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
MJR
Mar 16, 2003 08:26 PM
