Stalling issue
Old Jun 18, 2009 | 04:50 PM
higbee's Avatar
Stalling issue
I have an 02 2500 with 86,000 miles. Recently, I've had a stalling issue with no throttle response. I have been able to correct it by engaging the clutch, shifting into lower gear or rev-ing the engine. I don't know where to begin, fuel filter or sensor? Any ideas? Thanks!
Old Jun 18, 2009 | 05:19 PM
Beast2B's Avatar
Welcome!
any trouble codes? if you don't have a scanner try cycling the key on-off-on-off-on (not to start, just to run) the existing codes will be displayed in the odometer display. sounds like APPS or injection pump going south...
Old Jun 18, 2009 | 10:07 PM
higbee's Avatar
Thanks for the info. I will check the codes tomorrow.
Old Jun 18, 2009 | 11:39 PM
higbee's Avatar
What is APPS?
Old Jun 19, 2009 | 12:50 AM
Dinner's Avatar
APPS is Accelerator Pedal Position Sensor. It is located under the intake horn on the left side of the engine. Cable runs from the pedal to the APPS, where it converts mechanical movement into voltage readings for the PCM and ECM.
Old Jun 19, 2009 | 05:51 PM
higbee's Avatar
error codes with key say 1693 & 0216. I bought a code reader and got only 0216. I'm checking the APPS right now.
Old Jun 19, 2009 | 06:05 PM
ldornak's Avatar
I hate to break the bad news to you, but you better start saving for a new injector pump. 0216 is almost always associated with a bad VP-44.
Old Jun 19, 2009 | 06:07 PM
higbee's Avatar
Where is my intake horn? I'm looking for the APPS sensor....Help!
Old Jun 19, 2009 | 06:09 PM
higbee's Avatar
I guess I don't have this diesel language down, yet. VP44 = vacuum pump? Where is that located?
I have heard many things on this post from sensors to VP44's. I am figuring on starting with APPS sensor and work my way up.
Old Jun 19, 2009 | 07:50 PM
ldornak's Avatar
Look on the top of your intak manifold at the front of the engine on the drivers side. The intake horn bolts to the intake manifold. The other end of the horn attaches to the inter-cooler tube that runs down to the bottom of the inter-cooler. Your dipstick also is anchored to the intake horn. Directly in front of your intake horn, you'll see a black plastic cover. Take the plastic cover off and you'll see the APPS.
VP-44 is the injection pump. It's located below your APPS. On the back of the injector pump, you'll see the 6 high pressure lines that feed your injectors.
Good luck!
Sea:\>Drive
Feb 22, 2011 01:33 AM
Warhawk22
May 19, 2010 05:19 PM
stjames151
Jul 31, 2008 05:13 PM
ptgarcia
Feb 19, 2008 04:00 PM
DDysput
May 5, 2004 07:44 AM
