squeak
Old Mar 4, 2007 | 10:16 PM
dltriolo's Avatar
squeak
what is really the squeak noise when you shut down the engine and is there a way to make it stop? my truck use to always do this and now i noticed that it sometimes doesnt is there a way to make it quit all together?
Old Mar 4, 2007 | 11:28 PM
2500Ram's Avatar
It's the high compression of the engine when it suddenly stops causing the serpentine belt to slip some. More noticeable when everything is good and hot. it's not necessarily a need to replace the belt, just check it for wear and replace if necessary.
Old Mar 4, 2007 | 11:47 PM
yfz450guy's Avatar
it is normal.
Old Mar 4, 2007 | 11:48 PM
Tate's Avatar
I found that a dual disc clutch stopped the squeek.
Old Mar 5, 2007 | 02:00 AM
1-5-3-6-2-4's Avatar
you know what now that you mention it, I haven't heard mine squeek since the install.......
Old Mar 5, 2007 | 09:31 AM
dhughe2's Avatar
I havent noticed my truck squeak in months. it must be due to the new serp belt that had to go on to pass inspection
shep1
Aug 29, 2010 10:19 PM
CTD2001
15
Nov 28, 2009 07:54 PM
ytodd
Nov 2, 2007 09:57 AM
gman07
May 9, 2007 06:03 AM
hotdram
31
Sep 17, 2005 08:00 AM
