speedo not working right, and ABS + Brake warning
Old Jun 27, 2005 | 11:23 PM
57 chevy driver's Avatar
Question speedo not working right, and ABS + Brake warning
My speedometer started NOT working until the truck gets up to about 30 MPH, then it jumps up. Coming down from speeds higher than 30, it stops working about 27 or so, and the odometer stops working at this point as well.
The "ABS" light stays illuminated on the instrument panel.
The "BRAKE" light satys illuminated on the instrument panel.
All of this happened all at once.
Anyone have any clues? I checked some of the fuses, but all seem good.
Old Jun 27, 2005 | 11:36 PM
Kennys's Avatar
Mine did this and it was the sender on the rear axle. Don't remember exact cost but it wasn't very expensive to fix. Cost more for the dealer to diagnose and replace it that the part itself.
Old Jun 28, 2005 | 01:33 PM
hey kennys,
thanks for the quick reply.....great work! I now have to put one on order.
Old Jun 28, 2005 | 02:10 PM
Haulin_in_Dixie's Avatar
Yep a standard item to go bad. Just get the sensor from a dealer and takes at least 15 minutes to put it in. It is on top of the rear axle in the center.
Old Jun 28, 2005 | 07:06 PM
DarkPaladin's Avatar
Drain and clean out your rear diff too. They collect a lot of metal particles on them and that usually messes them up. I have had to clean lots and they work fine after cleaning.
Old Jul 2, 2005 | 07:52 PM
Hi all , got the rear axle sensor, and installed the new sensor and problems gone! Gawd this site is great!
I'll have the rear end oil changed and hope there are no more problems
Sleigher
May 4, 2017 02:12 PM
3J1&3J2Bill
Jan 27, 2011 01:14 PM
jmon12
Jan 29, 2007 07:50 PM
darrenG
Sep 13, 2005 02:37 PM
