some smoke
Old Nov 3, 2004 | 07:59 PM
d0dg301's Avatar
Question some smoke
Quick question about some smoke from my truck. I've noticed that when it's cold out around the freezing temp. outside, when I start my truck it will blow alittle white smoke and then it will be a blue colored smoke just when it's sitting there idilling. As soon as I get going and it warms up, the smoke goes away.
The truck runs very strong with no problems. Is this normal or should I be checking for something? Thanks.
Old Nov 3, 2004 | 08:42 PM
phox_mulder's Avatar
Bluish tint usually indicates burning oil.
If your oil level isn't going down, then it probably isn't.
If it was oil, you'd see it regardless of the outside temperature.
Maybe even moreso with high temperatures.
You can give the smoke a sniff, if it is just Diesel, you'll be able to tell,
same if there is burning oil in there, it'll smell like something from the 70's,
you also should be able to smell antifreeze if it is present.
More than likely, it is normal.
With cold weather setting in, mine will puff a little thick white off the bat,
then hazey white till it warms up enough to fully burn the fuel.
Down below 0 degrees it looks like a mosquito fogger till the engine temp gets up.
phox
Old Nov 3, 2004 | 09:03 PM
Forrest Nearing's Avatar
unburnt diesel is also blue...
it's normal when it's cold out.
my truck puts out a light blue haze all the time. 370's + advanced timing
Old Nov 4, 2004 | 06:24 AM
Tazman's Avatar
Perfectly normal.
Haven't seen one do any different under the conditions you describle.
Old Nov 4, 2004 | 10:12 AM
d0dg301's Avatar
Thanks for the comfort. I feel better now.
Old Nov 4, 2004 | 01:22 PM
ramtd02's Avatar
remeber diesel is infact fuel oil.....so yes it will be blue...loads of it will be black and a little will have a little bluish tint.
bensdad_canada
May 9, 2005 10:56 PM
dhe9
Nov 14, 2003 07:31 AM
PK
Oct 19, 2003 10:28 AM
jbs007
Jul 8, 2003 01:29 AM
97CTD
Mar 17, 2003 08:14 PM
