snapping in driveline
Old Jun 17, 2010 | 02:00 PM
roadhermit58's Avatar
'98 3500, drw, 4X4 sharp loud snapping noise when in 4wd, seems like coming from front drive axle, but maybe from transfer case? turns hard when in 4wd. Any ideas would be appreciated. 24 valve ,5 speed standard trans.
Old Jun 18, 2010 | 08:05 AM
Ruralmedic's Avatar
Check the condition of the double Cardan U-joint on the front propeller shaft coming off the T-case. Mine made a lot of noise when it was bad. My truck always turns hard in 4X4, especially if on a dry, hard surface. Feels as if the front tires are hopping, which seems to be normal operation with any 4X4 I've owned.
Old Jun 19, 2010 | 11:14 AM
Thanks , was thinking about that thing. also found transmission mount is NG.
I was afraid that the chain in the transfer case was giving trouble.
Old Jun 19, 2010 | 02:05 PM
Copenhagenjunkie's Avatar
It could be the TC chain, I swapped my tc out because of that. Just need to rebuild it for a spare.
Old Jun 21, 2010 | 01:59 PM
duster75's Avatar
Check your front axle Joints.... I've had them get STIFF from lack of use and actually bind up to where steering truck was affected. Nate
Old Jul 8, 2010 | 12:51 PM
Thanks for the replys, finally found the problem, u-joint on left axle shaft..........all fixed now
kgspeed700
Feb 14, 2009 03:34 PM
Common
16
Jun 23, 2007 12:30 PM
Burning Oil
Apr 12, 2007 06:48 PM
somis13
13
Sep 8, 2006 05:59 PM
Mexstan
25
Apr 30, 2003 04:26 PM
