sluggish rpm's
Old Jul 16, 2008 | 08:10 PM
cowboy2526's Avatar
sluggish rpm's
when i depress the throttle pedal it is slow to build up rpm's. i can hold down the pedal and it will top out at two grand and then slowly build up after that and max out at about twenty-eight hundred grand.
Old Jul 16, 2008 | 10:03 PM
TLDC's Avatar
What is your truck? If it's between about '99-'02 it sounds like the injection pump to me.
Old Jul 17, 2008 | 04:33 PM
cowboy2526's Avatar
yes its an 02 with 174k on it.
Old Jul 18, 2008 | 05:50 PM
TLDC's Avatar
from what I've found out when my truck had problems, they put the fuel pump in the fuel tank, after so many miles it can't get enough fuel to the injection pump which means then you usually have to replace the injection pump (VP44) and the fuel pump. Is your truck throwing any codes?
Old Jul 18, 2008 | 05:55 PM
tractorguyacb's Avatar
how about fuel pressure, and also is your turbo spooling. no or low boost will not allow fuel enrichment. also check the intercooler and connectors for blowouts.
Old Jul 18, 2008 | 06:17 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Start by reading any fault codes. Sounds to me like your truck is in a "limp" mode. I've had this same type is problem. After reading the fault code, I replaced my MAP sensor and I was back on the road. But your problem could be an injection pump issue, as mentioned above. But you just won't know intill the fault codes are read.
Old Jul 19, 2008 | 09:57 AM
cowboy2526's Avatar
its not throwing any codes and i have not paid any attention to see if the turbo is spooling, but i will do that now. thank for the help guys.
Old Jul 21, 2008 | 11:29 AM
JPR Ram's Avatar
No codes? OK, maybe the injection pump is ok. But obviously it sounds like a major lack of fuel. So first you need to check the fuel pressure at the injection pump; maybe the lift pump took a dump. If that is good, do a APPS reset.
Old Jul 21, 2008 | 11:34 AM
Diesel Doc's Avatar
Why not go the simplest route and change the filter first then work from there.
Old Jul 21, 2008 | 11:42 AM
klx650a2's Avatar
Get a FP gauge and then you'll know for sure, but yea change out the fuel filter and see what happens...
Old Jul 21, 2008 | 05:30 PM
JPR Ram's Avatar
So true...... I was just assuming that simple items like fuel filters and air filters would have already been replaced with new ones........
Old Jul 23, 2008 | 01:10 PM
cowboy2526's Avatar
sluggish rpms
I have changed the fuel filter two weeks ago. when the problem started. do i need to take it to a shop to get the fuel pressure checked or is that something i can do myself. how do i find out if the lift pump is bad? thanks for all the help!
Old Jul 23, 2008 | 02:37 PM
JPR Ram's Avatar
Yes you can check the fuel pressure yourself. But you will need a fuel pressure check gauge to do so. You can get one from Vulcan Performance or Kragen/AutoZone or Napa. As for how, there is a schaeder type valve on the injection pump. It'll be right where the fuel line (whiich comes from the fuel filter canister) goes into the injection pump. Attach the test gaueg to that. If the pressure is real low (anything under 5 psi, IMO) or non-exsistent, that'll usually mean the lift pump is bad.
Old Jul 23, 2008 | 02:41 PM
JPR Ram's Avatar
Have you tried an APPS reset yet? It's real easy to do. The instructions are on the top of this page under the heading "Tech Facts". All you really have to do is to disconnect both batteries for a short period of time; then the proceedure with the throttle peddle. Easy.
Old Jul 23, 2008 | 08:01 PM
cowboy2526's Avatar
sluggish rpms
no i have not tried the APPS yet. I will do that and also go get a fuel pressure tester. thanks for the help.
