silencer ring?
Old Jun 15, 2005 | 11:22 PM
JD farmboy's Avatar
Question silencer ring?
I keep reading stuff about a silencer ring on these cummins pickups, is there actually something else I can take off to make it louder? If so where is it and what is involved in removing it?
Old Jun 15, 2005 | 11:47 PM
dezlsmkr's Avatar
The air filter
Old Jun 16, 2005 | 12:29 AM
killfast1's Avatar
Dump the stock airbox and go with a BHAF or better. It will make it louder.
Old Jun 16, 2005 | 01:45 PM
RowJ's Avatar
Cut the hole for the Scotty II Air Intake! Be all set to go when you buy one, and lets a lot of turbo noise into cab....if that's what you really want!
RJ
Old Jun 16, 2005 | 05:36 PM
NHdodgeman's Avatar
If youve got the silencer ring removed already you can get a little more turbo whistle by removing the tube on the side of your airbox that goes into your fender well. takes 2 minutes to do and gets more air into the box. Its not clear wether or not you have removed your silencer ring... if not .. DO IT NOW!
Old Jun 17, 2005 | 09:20 AM
mike6256's Avatar
Ya, straight pipe it
Old Jun 17, 2005 | 11:26 AM
CapnRam's Avatar
BHAF?????
Ok havent been into the bombing thing to much, EZ, lost my muffler and resonator, silenceing ring gone, gauges, and a K&N air filter....? is what is a BHAF,,,i see it alot in the signatures, i'm sure it has something to do with the air filter...maybe i'm just brain fartin this but ya got me...thanks
Old Jun 17, 2005 | 11:27 AM
NHdodgeman's Avatar
I second the straight pipe motion ... makes the turbo much more pernounced.
Old Jun 17, 2005 | 11:42 AM
Korney's Avatar
All that is gonna do is give your Cummins hot air coming off the engine. Sounds good but you are defeating the purpose of the intercooler. My truck came with an open air box and some kind of cone filter. It would probably be better if I had hood insulation to seal it more but I don't and I think I'm getting warm air too. I am looking into fitting it better cause that hole in the fendr is an ideal place to get fresh air.
Old Jun 17, 2005 | 12:15 PM
phox_mulder's Avatar
Re: BHAF?????
Big Honkin' Air Filter.
Go to Members Photos and do a search for BHAF, you'll see the many flavors that qualify.
phox
Old Jun 17, 2005 | 10:31 PM
AKDSLDOG's Avatar
I chose the straight 4" DPP Exhuast, Scotty II w/hole cut, silencer ring gone. Yes it sounds ssswswwwweeeeeeeeet! Thinking about going to a 5" system, just for sound. Yes I am sick.
To remove your silencer ring, Take air intake off of the turbo, look in there and you will see a coned shape peace held in by a internal snap ring. Look with a flash light and take 2 number 2 screw drivers, pry one end down then peel it out with the other and TOSS IT IN THE GARBAGE! next hook up intake and go wor a ride with a smile! NOISE!
Old Jun 17, 2005 | 10:54 PM
JD farmboy's Avatar
Yeah, I already have a straight pipe, (stock with muffler cut out) who has the best price on a 5", and also I am interested in getting an Edge EZ, my truck has 172,000 miles on it, is this a good idea or not, you know with this many miles and all, putin' that much more pressure on the rings may make it start using oil???? Also, where can I get the best price on pillar mounted guages? I need a fuel pressure guage and would like also to have EGT and Boost. I like what Auto Meter has to offer, (had a set on my old Powerstroke). Thanks for your help guys!
Old Jun 18, 2005 | 01:47 AM
killfast1's Avatar
Heck at 172K you arnet very far past breakin so I would not worry about it. But after all of my reading I would go with the Edge Comp, just dont tap the fuel wire and it works as an EZ. Then later on when you have another itch you can tap the pump wire and hold on. This way you dont have to buy another box.
Thats what I plan on doing at least as money permits.
Old Jun 18, 2005 | 07:08 AM
Mopar1973man's Avatar
Try going to DPP for gauges...
http://www.dieselperformanceparts.co....pl/dieselshop
I paid $309.00 for pillar, FP, Boost, pyro, can of grey paint. Dipricol white faced...
Photo's of all my bombs are in my gallery...
Old Jun 20, 2005 | 12:28 PM
38 Cigarette's Avatar
Smile
I got my Di Pricol's from Geno's Garage.
RonP
Feb 17, 2010 09:30 AM
RRC
May 13, 2007 11:45 PM
HaulinBut
May 12, 2006 03:06 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
