Shifting Promblem
Old May 22, 2008 | 01:51 PM
BSPENCE10's Avatar
Unhappy Shifting Promblem
I Have 98 Dodge 3500 Automatic.just Started Shifting In And Out Of Overdrive At 70.any Ideas,DOESNT SEEM TO AT LOWER RPMS
Old May 23, 2008 | 02:02 AM
dozer12216's Avatar
Assume the fluid level has been checked and is full and fluid color O'K.
It seems unlikely that a gov solenoid or pressure transducer is malfunctioning at 70 MPH. ABS speed sensor and RPM sensor should be O'K also. It may be a very sensitive brake switch. Try holding very light lifting pressure from under brake pedal and see if that gives relief.
Try adding a extra pint of ATF. I have heard instances and experienced on my own, that tranny needs just a little more fluid level at highway speeds.
BSPENCE10
Sep 29, 2010 11:12 PM
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
lyvwire
Mar 20, 2003 07:45 AM
